timing belt problem...
Old Jan 28, 2004 | 02:50 PM
pootie.teng's Avatar
Default timing belt problem...
yo i can't get my TDC marks on my cam gears to line up with the TDC mark perfectly. it sems like its always off by a little bit. like half a centimeter. i tried hella hard and many times but still can't line it up exactly. is this normal? runing ls/vtec, gsr water pump, gsr timing belt...
Old Jan 29, 2004 | 08:08 PM
Default Re: timing belt problem... (teckno_geek)
dang someones got to know wassup.
Old Jan 29, 2004 | 08:22 PM
Wes d's Avatar
Was the head milled? If so, your marks will be off.
Old Jan 29, 2004 | 08:28 PM
Default Re: timing belt problem... (Wes d)
i had it resurfuce twice. everytime about .002. but i don't think it would throw it off that much.
Old Jan 29, 2004 | 09:29 PM
hondatim's Avatar
the marks a lot of times won't be absolutely perfectly lined up. It is normal for them to be off from one another as much as 1-2mm. No more than this though. If you do, indeed, have half a centimeter of variation, it may be off a tooth. best way to know is to set you belt on with marks as close as you can get them. Then allow tensioner to add tension to belt and then, using socket and breaker bar, turn engine over 3-5 revolutions and put crank back at TDC and then inspect to see if cam marks are still off or are lined up. If lined up (again within 1-2mm of each other), belt should be properly installed and you should be able to continue. If marks are a tooth or more out, obviously, they are not in time and must reinstall belt again.
Hope this helps...
PS. don't forget to set ignition timing after t-belt installed.
Old Jan 29, 2004 | 09:34 PM
mmuller's Avatar
Mad Scientist
Default Re: timing belt problem... (hondatim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatim &raquo;</TD></TR><TR><TD CLASS="quote">the marks a lot of times won't be absolutely perfectly lined up. It is normal for them to be off from one another as much as 1-2mm. No more than this though. If you do, indeed, have half a centimeter of variation, it may be off a tooth. best way to know is to set you belt on with marks as close as you can get them. Then allow tensioner to add tension to belt and then, using socket and breaker bar, turn engine over 3-5 revolutions and put crank back at TDC and then inspect to see if cam marks are still off or are lined up. If lined up (again within 1-2mm of each other), belt should be properly installed and you should be able to continue. If marks are a tooth or more out, obviously, they are not in time and must reinstall belt again.
Hope this helps...
PS. don't forget to set ignition timing after t-belt installed.</TD></TR></TABLE>
ps:your timing will be rougly 1/2 degree off because of the milling
Old Jan 29, 2004 | 10:01 PM
hondatim's Avatar
Default Re: timing belt problem... (mmuller)
good call dude!
Forgot all about that as I got into my novel above.
Old Jan 30, 2004 | 12:02 PM
dude tight. that was more then anything i ever gotten from anyone. i guess i'll go and try again. hopefully it didn't damage my new crower valves i bought. haven't put it in my car but all the crankn i've been doing to try to align the TDC marks, hopefully didn't mess them up along with my new arias pistons. but wait do you think it could of mess them up. now you guys got me all scared. sh*t hopefully everything is all cool. didn't feel any resistance when turning the crank. read that if i did feel resistance then the valves are contacting the pistons but i didn't so hope everything is okay.
Old Jan 30, 2004 | 06:58 PM
hondatim's Avatar
everything should be OK if you just rotated it over by hand...
I wouldn't worry too much.
Just hope we helped!
raverx3m
Aug 31, 2013 08:43 PM
fatpride111
10
Nov 20, 2008 07:05 AM
eg6d15
Jan 7, 2008 01:21 PM
SHG_EasyE
Mar 9, 2005 10:10 AM
ActiveAero
Aug 18, 2003 12:42 PM
