Tranny check up/ repair on 92 accord
After 100,000 miles, should i service the tranny??? also, is it safe to still put a turbo on an engine with that many miles??? Are there any bearings i should lube on the tranny???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elderjoe »</TD></TR><TR><TD CLASS="quote">After 100,000 miles, should i service the tranny??? also, is it safe to still put a turbo on an engine with that many miles??? Are there any bearings i should lube on the tranny???</TD></TR></TABLE>
Are you planning on doing something(new clutch, FW...) or are you just asking about checking your tranny?
Where is your clutch letting out at? If you have to let out almost the whole pedal then from past exp. It may be your slave cylinder is leaking. Not sure though.
