Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
G*R*E*D*D*Y Turbo Kits Start @ $1445 SHIPPED! and Intercooler Kits Start @ $620 Shipped!
Old Jan 28, 2004 | 11:46 AM
shauniewalnuts's Avatar
Default G*R*E*D*D*Y Turbo Kits Start @ $1445 SHIPPED! and Intercooler Kits Start @ $620 Shipped!
All GReddy Turbo exclusively use GReddy Spec. Mitsubishi Turbochargers. Our kits are design and tested to match the best-sized turbo per application. This means you get good response, smooth driveability, performance that can still be upgraded, and lasting reliability. It takes a tremendous amount of money and time to successfully increase the power of a naturally aspirated engine. With GReddy bolt-on turbocharger kits, you can obtain instant horsepower gains with less time and money, while still having room for upgrading.
Turbo Kits are as Follows:
RSX Type S - $2449 shipped ($3449 Retail)
96-00 GSR/LS/RS - $2310 shipped ($3249 Retail)
99-00 Si - $2250 shipped ($3149 Retail)
96-00 Ex - $1875 shipped ($2599 Retail)
92-95 Ex/Si - $1445 shipped ($1995 Retail)
97-99 Prelude Type S - $2449 shipped ($3449 Retail)
******<U>02-04 Civic Si EP3 - $2449 shipped ($3449 Retail)</U>****** New Just Added!
*other non honda/acura model avail also
V-Spec. Core Depending on the application and usage, some turbocharged set-ups require different flow characteristics. To add to our tuning choices, GReddy developed the V-spec. line of intercooler cores with an inner "Micro Grove Tube" design. This design was developed to allow for larger cores that give good cooling with a more free flowing internal core. This is ideal for applications with low to medium-high boost levels in factory turbocharged engines or normally aspirated engines with bolt-on turbo kits. R-Spec. Core GReddy R-Spec. cores feature a high heat-dissipating "Inner fin" design. This is ideal for medium to high boost levels on higher horsepower or upgraded turbo engines. The larger internal surface area provides superior cooling efficiency for radiating excessive heat and minimizing heat soak. Some R-spec. kits are labeled "HG" or High Grade; these kits feature piping and end tanks that have been hand-polished to a mirror finish for the ultimate in show quality aesthetics. R-Spec. Core GReddy R-Spec. cores feature a high heat-dissipating "Inner fin" design. This is ideal for medium to high boost levels on higher horsepower or upgraded turbo engines. The larger internal surface area provides superior cooling efficiency for radiating excessive heat and minimizing heat soak. Some R-spec. kits are labeled "HG" or High Grade; these kits feature piping and end tanks that have been hand-polished to a mirror finish for the ultimate in show quality aesthetics. R-Spec. Core GReddy R-Spec. cores feature a high heat-dissipating "Inner fin" design. This is ideal for medium to high boost levels on higher horsepower or upgraded turbo engines. The larger internal surface area provides superior cooling efficiency for radiating excessive heat and minimizing heat soak. Some R-spec. kits are labeled "HG" or High Grade; these kits feature piping and end tanks that have been hand-polished to a mirror finish for the ultimate in show quality aesthetics.
Intercooler Kits are as follows:
96-99 GSR/LS/RS
Large - $810 shipped ($1067 Retail)
Standard - $715 shipped ($939 Retail)
99-00 Si
Large - $760 shipped ($995 Retail)
Standard - $620 shipped ($800 Retail)
92-95 Ex/Si
Large - $810 shipped ($1069 Retail)
Standard - $630 shipped ($849 Retail)
Large - $980 ($1290 Retail)
Standard - $790 ($1020 Retail)
VOUCHES IN SIG
Accept Paypal, Money Orders or Cashiers Checks
PM or Post with any questions!
Thanks Guys... Need Anything else JUST LET ME KNOW
Shaun Clark, http://www.blackphoenixtech.com
Modified by shaun311 at 10:25 PM 3/12/2004
Old Jan 28, 2004 | 04:00 PM
2FASTDC2's Avatar
Default Re: G*R*E*D*D*Y Turbo Kits Start @ $1445 SHIPPED! and Intercooler Kits Start @ $620 Shipped! (shaun
great prices
Old Jan 28, 2004 | 04:08 PM
japrex's Avatar
how about a turbo and intercooler kit for an 88 crx with a b16a???
Old Jan 28, 2004 | 04:42 PM
Default Re: (japrex)
Ok... this is what I came up with Si turbo kit $2250, and a RevHard 88-91 civic Intercooler kit for a b16 for $760 shipped... yay or nay? let me know if not ill keep brainstorming!
Old Jan 28, 2004 | 04:48 PM
Default Re: (shaun311)
japrex pm sent!
Old Jan 28, 2004 | 06:50 PM
Aquafina's Avatar
Will the Greddy kit and large intercooler work with a 00 Integra LS?
Old Jan 29, 2004 | 05:46 PM
Default Re: (Aquafina)
yep itll fit come one i know someone needs a turbo or intercooler kit cheap as hell!
Old Feb 2, 2004 | 11:46 AM
Old Feb 2, 2004 | 04:51 PM
Kelly.'s Avatar
I've quit using this account
you got mail
Old Feb 2, 2004 | 08:11 PM
Aquafina's Avatar
LS/VTEC using non ported B16 head, B16 LSD tranny, and B18B block, with Skunk2 stage 2's (yes, I know tuning will be hard) what kit and intercooler would you recommend?
Old Feb 3, 2004 | 05:20 AM
PM Sent
Old Feb 4, 2004 | 10:53 PM
cracker099's Avatar
How long will this last?
Old Feb 5, 2004 | 06:54 AM
Should last until stock runs out probably till the end of Feb Maybe till middle od March for them tax checks
Old Feb 5, 2004 | 08:51 AM
cracker099's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shaun311 &raquo;</TD></TR><TR><TD CLASS="quote">Should last until stock runs out probably till the end of Feb Maybe till middle od March for them tax checks </TD></TR></TABLE>
Old Feb 6, 2004 | 10:32 AM
Kelly.'s Avatar
just ordered mine today.
so far i have gotten great communication.
Old Feb 9, 2004 | 12:00 AM
rMak's Avatar
Default Re: (llewsirc)
is the 96-00 civic ex kit street legal like the 92-95?
Old Feb 9, 2004 | 03:36 AM
Default Re: (slowEJ8)
yep
Old Feb 11, 2004 | 06:38 AM
jimsterli's Avatar
I'm interested in a turbo kit for my 96 Civic Hatchback with b18c1.
Any recommendations on what bolt-on kit I need?
Thanks.
JLi
Old Feb 11, 2004 | 06:49 AM
PM Sent!
Old Feb 11, 2004 | 10:38 PM
kcjohnnyboy's Avatar
how much for greddy kit for 99 integra gsr with type 31 intercooler? come with e-manage right also?? thanks
Old Feb 12, 2004 | 08:47 AM
adotlee's Avatar
shaun did you recently open your store!? i live in nj and i have never heard of your place. maybe il try to stop by one day. do you have a dyno????
Old Feb 12, 2004 | 09:37 AM
PMs sent
Old Feb 15, 2004 | 11:37 AM
ej1 pilot's Avatar
ill buy one...in july lol
Old Feb 15, 2004 | 01:20 PM
let me know when you are ready!
Old Feb 20, 2004 | 05:47 AM
Kelly.'s Avatar
got mt kit today.
everything came in great condition, packing was great.
great customer service. buy from this guy!
