wiring prob. ANY IDEAS?
Old Jan 28, 2004 | 11:20 AM
zangiefisgod's Avatar
Default wiring prob. ANY IDEAS?
ok here are the symptoms...
my fan won't come on = fast overheat
my tach jumps around after 5500 at more than half throttle
ps: 94 LS motor, fan plugged in, all fuses are good... im sure its a short somewhere, but where should i start too look?
Old Jan 28, 2004 | 11:54 AM
nevamind's Avatar
Default Re: wiring prob. ANY IDEAS? (zangiefisgod)
First thing to do is check whether your fan is working by disconnect the fan from the switch then use a small wire to connect the two terminal on the plug together. If the fan running when you turn on the ignition then the fan is in working condition. Let assume that the fan is working, try replace your fan switch; if the problem still persist, then try replace the thermostat. Hope this help
Old Jan 28, 2004 | 12:03 PM
lovitalracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zangiefisgod &raquo;</TD></TR><TR><TD CLASS="quote">my tach jumps around after 5500 at more than half throttle
check the speed senser and the distributer can cause that too .. Plug wires and all
Old Jan 28, 2004 | 09:35 PM
Mochanic's Avatar
Default Re: wiring prob. ANY IDEAS? (lovitalracer)
probably not related...
the tach is jumping around due to a loose wire on the side of the igniter inside the distributor, unplug it (the blue wire) squeeze the female connector a little tighter then reinstall it.
as for the fan, you should first check the fuse, then try swapping the relays out with another one next to it. If it still doesnt work, check for power and ground a the fan connector. Most likely this will find/fix the problem. if there is both, you need a new fan, if theres not both, find out why... the thermal switch on the thermostat housing provides the ground to the relay, so by jumping it you will only activate the relay.
PM me if this doesnt help you!
EscoSi
Feb 1, 2012 06:24 AM
ngoldsmith1@gmail.com
10
Nov 27, 2008 01:04 PM
Eglifestyle
10
Mar 23, 2008 12:08 PM
quick_ls
Mar 9, 2006 05:56 PM
goldito187
Oct 30, 2003 11:18 AM
