tires for 225/50/16 or should i go 225/45/16?
Old Jan 28, 2004 | 10:49 AM
done's Avatar
Default tires for 225/50/16 or should i go 225/45/16?
Kumho Ecsta v700 $148
Bfg geforce T/A kd $159
Kumho Ecsta MX $104
Pontenza S03 $153
Im leaning toward bfg geforce T/A or the S03.
Reason being, I believe strongly the bfg can hold most of what i throw at it. and the side walls are to stiff or to soft.
S03s being higher ratings, cheaper, longer life.
Old Jan 28, 2004 | 10:53 AM
DC2R714's Avatar
Default Re: tires for 225/50/16 or should i go 225/45/16? (Jordo)
I am going with the V700's. I hear really good things about these tires and I heard they will last awhile too. I thought about the BFG's but they don't last long at all and are more expensive to replace if you have to do it every 5000 miles.
Old Jan 28, 2004 | 11:00 AM
Big Phat R's Avatar
Those sizes are large - you will need <40mm offset to clear those
225/40 or 215/45 is the correct aspect ratio for 16"
Old Jan 28, 2004 | 11:01 AM
.RJ's Avatar
.RJ
the v700's are race/track/autox tires.
Old Jan 28, 2004 | 11:03 AM
done's Avatar
Default Re: tires for 225/50/16 or should i go 225/45/16? (Big Phat R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">Those sizes are large - you will need &lt;40mm offset to clear those
225/40 or 215/45 is the correct aspect ratio for 16"</TD></TR></TABLE>
my wheels are 45mm offset
Old Jan 28, 2004 | 11:13 AM
Mindtrap's Avatar
ot - would switching from a large size to a smaller wheel/tire or vice versa change the car's alignment?
Old Jan 28, 2004 | 12:55 PM
AamirCWITR's Avatar
Default Re: tires for 225/50/16 or should i go 225/45/16? (Mindtrap)
your looking at the wrong size tires,
205 45 16 or 215 45 16 or 225 40 16
Old Jan 28, 2004 | 01:00 PM
norice's Avatar
Default Re: tires for 225/50/16 or should i go 225/45/16? (AamirCWITR)
225/45/16 PZero Assimetricos are also an option and cheaper than all of the above. Amazing tires.
Old Jan 28, 2004 | 01:21 PM
done's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AamirCWITR &raquo;</TD></TR><TR><TD CLASS="quote">your looking at the wrong size tires,
205 45 16 or 215 45 16 or 225 40 16</TD></TR></TABLE>
how am i looking at the wrong tires..
those tires i posted, come in the following size 225/50/16
Old Jan 28, 2004 | 01:52 PM
Nishant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo &raquo;</TD></TR><TR><TD CLASS="quote">
those tires i posted, come in the following size 225/50/16</TD></TR></TABLE>
wrong tire size for your wheels... if you have 16's with +45 offset
you should get 215/45/16
Old Jan 28, 2004 | 02:06 PM
Big Phat R's Avatar
Jordo - the tires you a looking at are too big -
Use this : http://miata.net/garage/tirecalc.html
<u>Stock tire size</u> = 195/55-15
Diameter is 595.5 mm Circumference = 1870.8 mm 535 revs/km
<u>Your new size</u> = 225/50-16
Diameter is 631.4 mm Circumference = 1983.6 mm 504 revs/km
Not only are they TOO WIDE and heavy. They are too tall and will give you a 6% speedometer error. They will also hurt acceleration.
215/45-16
Diameter is 599.9 mm Circumference = 1884.6 mm 531 revs/km
which is only a 0.7% difference
Old Jan 28, 2004 | 04:24 PM
done's Avatar
215/45-16
i dont thikn 215s are gonna hold 350whp+
Old Jan 28, 2004 | 05:08 PM
Big Phat R's Avatar
Jordo-
The shape of the contact patches will not be signficantly different between a 215 section width tire and a 225 section width tire.
The SIZE of the contact patch is determined by the weight of the car - not the size of the tire. This has been discussed on numerous occasions and George Knighton would be happy to re-discuss this topic with you.
If you seek better traction - more gains are to be had from selecting the right tire compound, a better LSD and traction bars if necessary.
Channelling 350 whp through the front tires of a FWD car is going to be a mechanical challenge anyway. Torque steer is going to be a major problem - along with getting all that power to the ground in an effective manner.
Bigger wider tires are only going to worsen torque steer.
Old Jan 28, 2004 | 05:18 PM
Kicker773's Avatar
good info for future tire purchase
Old Jan 28, 2004 | 05:21 PM
done's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">Jordo-
Oh really, this information is totally foreign to me. Im thought wider is better.
I cant find any tires in 215/45/16
Old Jan 28, 2004 | 05:27 PM
buji's Avatar
New User
I cant find any tires in 215/45/16</TD></TR></TABLE>
http://www.falkentire.com/tires/az_rs_sizes.htm
Old Jan 28, 2004 | 05:38 PM
done's Avatar
Default Re: tires for 225/50/16 or should i go 225/45/16? (buji)
only azenis are the tires that come in that size..
allt he other one are 225/50/16
Old Jan 28, 2004 | 05:40 PM
buji's Avatar
New User
I'm pretty sure RE010s come in that size too.
Old Jan 29, 2004 | 01:08 AM
Pondus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buji &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure RE010s come in that size too.</TD></TR></TABLE>
Yes they do, and you can also get Michelin Pilot Sport in 215/45/16 but they are $$$$$$$
Old Jan 29, 2004 | 01:27 AM
Unsung's Avatar
Default Re: tires for 225/50/16 or should i go 225/45/16? (99ITR#3715)
Tires get wider to compensate for softer compounds. The only thing width does is dissipate heat better for soft compound tires.
LLCjr
Jan 2, 2009 08:31 PM
Suzukablue
Nov 28, 2005 10:21 PM
Wrath of VTEC
Aug 26, 2001 11:39 PM
FBP_1171
Jul 30, 2001 09:28 AM
