lsd on B16
Old Jan 28, 2004 | 08:27 AM
jdmcivicb16's Avatar
Default lsd on B16
If I put a type R lsd in my b16 will I run into any problems and or need other parts?
Old Jan 28, 2004 | 09:05 AM
rice a roni's Avatar
Default Re: lsd on B16 (jdmcivicb16)
whats an lsd?
Old Jan 28, 2004 | 09:08 AM
HNDAPWR's Avatar
Default Re: lsd on B16 (sohc_civic)
limited slip differential, or a hallucinagenic drug.
Old Jan 28, 2004 | 09:09 AM
HNDAPWR's Avatar
Default Re: lsd on B16 (HNDAPWR)
Actually, the lsd doesn't go in the b16, it goes in the trans. It all depends on what trans you have.
B16Drag's Avatar
Thats messed up! hah
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_civic &raquo;</TD></TR><TR><TD CLASS="quote">whats an lsd?</TD></TR></TABLE>
Old Jan 28, 2004 | 09:10 AM
B16Drag's Avatar
type r tranny should be a bolt on if the car was b-series hydro in the first place
do you mean tranny or the actualy LSD mechanism?
Old Jan 28, 2004 | 09:11 AM
nY's FiNeSt's Avatar
Default Re: lsd on B16 (B16Drag)
he just wants the itr diff in his trans, not the whole itr tranny
you won't run into any problems, just make sure the diff isn't messed up and get new bearings
Old Jan 28, 2004 | 09:12 AM
B16Drag's Avatar
how much are you spending on that thing... if its expensive get the Quaife or the Kaz LSD
Old Jan 28, 2004 | 09:13 AM
Default Re: (B16Drag)
I found it for $300.00
Old Jan 28, 2004 | 09:14 AM
HNDAPWR's Avatar
Default Re: lsd on B16 (nY's FiNeSt)
I have a 99 Si trans w/ a Quaiffe lsd and I love it. I believe that would make it the same as a type-r except for the final drive.
Old Jan 28, 2004 | 09:16 AM
FrostySol's Avatar
how "involved" is adding a lsd? Like do you just slap it on the end of the tranny or do you have to crack open the tranny case and put it in there?
Old Jan 28, 2004 | 09:24 AM
HNDAPWR's Avatar
Default Re: lsd on B16 (FrostySol)
You have to open it up, its fairly involved. I wouldn't try it if I were a first timer.
Old Jan 28, 2004 | 09:27 AM
reaction360's Avatar
correct me if i'm wrong, but doenst only the ctr lsd fit in b16s and LS's, and itr lsds fit in gsr's?
Old Jan 28, 2004 | 09:40 AM
mattssi's Avatar
Default Re: lsd on B16 (reaction360)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reaction360 &raquo;</TD></TR><TR><TD CLASS="quote">correct me if i'm wrong, but doenst only the ctr lsd fit in b16s and LS's, and itr lsds fit in gsr's?</TD></TR></TABLE>
You stand corrected!
Old Jan 28, 2004 | 09:54 AM
H22A EG6's Avatar
Default Re: lsd on B16 (mattssi)
300 bux get it you will love it
da6xsi06
Transmission & Drivetrain
Oct 6, 2010 04:47 AM
essex
Jul 9, 2008 08:37 PM
kev tec96
Mar 10, 2004 07:11 AM
4drferio
Mar 2, 2004 09:45 PM
