what does a bypass valve do on a...
Old Jan 28, 2004 | 06:20 AM
6snoop6's Avatar
Default what does a bypass valve do on a...
what does a bypass valve do on a cold air intake for a 92 accord with an f22a1??? What are the benefits of putting one on???? Please explain the reason for putting one on.
Old Jan 28, 2004 | 06:43 AM
a4thgenaccord's Avatar
Default Re: what does a bypass valve do on a... (6snoop6)
A Bypass valve on ANY CAI for ANY car helps kep water from getting into the motor. CAI have a tendency to pick up water when it rains fromthe road and suck it right into the motor, the bypass valve helps catch the little water dropletrs and save your motor, If you put on a CAI you are better off paying the extra money for the bypass vale then to pay $100's for a repair job.
I hope this helped answer your question.
Old Jan 28, 2004 | 09:44 AM
Monkey Fing a Coconut's Avatar
Default Re: what does a bypass valve do on a... (a4thgenaccord)
the bypass valve is way up in the engine bay because if the entire filter were to become submerged in water then the air would flow in through the bypass valve and not through the submerged filter in the bumper, i dont think it catches little droplets that make it through the filter cuz a few droplets of water wont hurt the engine anyways
Old Jan 28, 2004 | 09:57 AM
accord20o1's Avatar
Default Re: what does a bypass valve do on a... (twistedbydezign)
yea i heard that too.. few drops of water doesnt hurt ur engine. i heard it only hurts it when the water is flooded up to the filter
Old Jan 30, 2004 | 12:16 AM
Riceburner247's Avatar
Default Re: what does a bypass valve do on a... (accord20o1)
Uh, yeah, I don't think the bypass valve acts as a filter for incoming water elements. sooooo, forget that.
The bypass valve is what it's called, a valve.
The best example I can think of is with a straw. Take a straw and cut a small section out of the middle. Don't cut it in half, just a small hole out of one side. Then try to suck water out of a glass with the straw. It'll be hard to get water through the straw because the hole in the middle is providing the air supply when the end of the straw is blocked.
The hole in the straw is the bypass valve. It provides air only when it is needed.
dj theoretic
Mar 2, 2009 03:17 PM
ic89
Oct 25, 2006 10:51 PM
Tad
Sep 12, 2003 06:29 AM
infinkc
17
Dec 2, 2001 02:40 AM
iCcharliee
Nov 27, 2001 07:46 PM
