camber question
ok, my teg is lowered 2" in front and 1.75" in rear....the camber on the front wheels is very noticeable, a friend estimated about -2 degrees. what should i get the camber adjusted to? and what's a good kit to use?
I am lowered 1.8" all the way around and the alignment guy set my fronts to -.5 for street use. I went with the ingalls extreme kit with rubber bushings and wahsers at the back.
I ordered from importstop.net (they have a GB right now)... http://www.groupbuycenter.com/buy.as...ad&row_id=3421
Then i had the shop install it for me and align.
hey, on the group buy it says that the kit isn't recommended for a drop more than 1.25".....is that for the accord (which the recommendation comes after) or is it for all of those kits?
What i got: 3572/3573 Adj: +1.25 to +3.0 $130 (with rubber bushings)
I think this is what you need also since you're dropped 2"
Send them an email, they'll take care of you.
Blue10karat
Feb 13, 2005 06:39 PM
