97 d16y8, 95 b18c,same knock sensor???
Old Jan 27, 2004 | 08:02 PM
robtec's Avatar
Default 97 d16y8, 95 b18c,same knock sensor???
i want to know if these two engines uses the same knock sensor??
Old Jan 27, 2004 | 09:02 PM
Se-rv-Tak's Avatar
Default Re: 97 d16y8, 95 b18c,same knock sensor??? (robtec)
If I am correct, I believe the D16y8 does not house a Knock Sensor. But from what I was told a while back, you need to use B-series KS anyways.
Old Jan 27, 2004 | 09:28 PM
robtec's Avatar
Default Re: 97 d16y8, 95 b18c,same knock sensor??? (Se-rv-Tak)
the d16y8 uses a ks, i am asking cause i am running a p72 ecu on my 95 ex,but i am using a y8 block,and it have an opening for the ks.i will like to know if a b18c and y8 ks are the same,cause in a few months my friend will be needing a ks for his b18c that he is going to install in his del sol,along with the p72 ecu i am curently using.
Old Jan 27, 2004 | 10:35 PM
robtec's Avatar
are the b series and d series ks interchangeable???
does a knock sensor for an obd1 ecu difers from the one for a obd2 ecu??
Old Jan 28, 2004 | 08:09 AM
Se-rv-Tak's Avatar
the 96-00 civic EX ecu, does not read a knock sensor... so it should not have one.
Old Jan 28, 2004 | 11:32 AM
robtec's Avatar
yes they read a ks.the y8 block that i am using came with one,and in my friends 96 ex also have one.
Old Jan 28, 2004 | 01:05 PM
Se-rv-Tak's Avatar
well, if hondaswap was working, I would show you that it doesnt.
Old Jan 28, 2004 | 01:40 PM
robtec's Avatar
no body else,i don't know of hondas in P.R. are diferent,but here 96+ civic ex came with a ks.i know what a ks is,and my y8 block had one but is was broke.
Old Jan 28, 2004 | 02:38 PM
MrTodd's Avatar
Guess what?
Y8 blocks DO have a knock sensor! (96-00 EX)
I really don't think the sensors are the same between the D and B series, BUT, If it fits then you should be able to use it. They all operate in a similar fashion. The differences should only be in placement and size/shape... It's definitely worth a try.
Old Jan 28, 2004 | 02:55 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">the 96-00 civic EX ecu, does not read a knock sensor... so it should not have one.</TD></TR></TABLE>
the 96-00 civic ex has a knock sensor...i thought everything with vtec has a KS. but i know for a fact that the d16y8 has a KS.
i looked on hondaautomotiveparts.com and the part number for the 99 d16y8 KS is 18478. i looked for a 99 b16a2 also but couldnt find the listing.
on autozone.com the part numbers are the following:
99 d16y8 - SU4778 $105
99 b16a2 - SU4779 $112
95 b18c1 - SU4779 $112
so i am not sure. my guess was that they might be interchangable...but now i am not too sure about that. sorry. anyone else?
Old Jan 28, 2004 | 03:12 PM
PHiZ's Avatar
It is, and it does.
http://www.hondaswap.com/forum...29360
-PHiZ
Old Jan 28, 2004 | 08:16 PM
robtec's Avatar
thanks people,thats all i wanted to know.
Old Jan 28, 2004 | 09:18 PM
Se-rv-Tak's Avatar
Default Re: (robtec)
mmmm well according to Hondaswap.com's reference... it said it did not, house a KS..... but I guess they were wrong, and that's where I got the info from, so I too was wrong... sorry.
Old Jan 28, 2004 | 09:34 PM
chictunner97ex's Avatar
Default Re: (Se-rv-Tak)
just to let you guys know i did use a B series knock sensor in my D16Y8 and it worked just fine. it is the same size and shape...just black not blue. but it works.
Old Jan 29, 2004 | 08:30 PM
robtec's Avatar
Default Re: (chictunner97ex)
super, now i know for sure!!
Labarum
21
Aug 7, 2011 04:28 AM
jr000
Aug 30, 2007 09:50 AM
THC07
Oct 2, 2005 01:31 PM
redpeppers
Sep 15, 2005 06:42 AM
mugenhatch92
15
Jul 21, 2004 09:52 PM
