OBD0 injector clips same as OBD1 clips?
Old Jan 27, 2004 | 06:29 PM
D16A6Turbo's Avatar
Default OBD0 injector clips same as OBD1 clips?
Curious because I know precision injectors fit OBD1 clips but I have OBD0 D16A6. Wanna know if I can run them w/ no problems...
Thanks
Old Jan 27, 2004 | 07:04 PM
Sonny's Avatar
Default Re: OBD0 injector clips same as OBD1 clips? (D16A6Turbo)
You can run them with no problems.
Sonny
Old Jan 27, 2004 | 09:48 PM
D16A6Turbo's Avatar
Default Re: OBD0 injector clips same as OBD1 clips? (Sonny)
thanks...
Old Jan 27, 2004 | 09:59 PM
TravSi's Avatar
obd1 and obd0 clips are different....you should just look into getting peak/hold injectors which is what obd0 hondas run instead of the saturated which is what is on the obd1 honda or you can modify the clips to fit on the obd1 injectors its simple (utility knife, 5 minutes and yur done) You just have to cut out the little tabs inside the clips so it will slide onto the injector, (you will see when you compare the injector to the clips on your car) it worked for me....
Old Jan 27, 2004 | 10:19 PM
D16A6Turbo's Avatar
Default Re: OBD0 injector clips same as OBD1 clips? (TravSi)
The 880cc precision injectors are peak and hold I believe, so I should be good...anyone care to clarify...
BoRiCuA
Jul 6, 2013 08:57 AM
CRX44
Aug 31, 2009 11:13 PM
jakscivic
Feb 12, 2007 09:13 PM
Schister66
Apr 25, 2006 10:21 PM
