Supercharger for a type r
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR15 »</TD></TR><TR><TD CLASS="quote">any one out there have a supercharged type r. Is it safe to super charge a type r without doing any motor work?</TD></TR></TABLE>
its not good for it...depending on how much boooooooost u run depends on how long the stock motor will last
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hype-aaaRRRR »</TD></TR><TR><TD CLASS="quote">
its not good for it...depending on how much boooooooost u run depends on how long the stock motor will last</TD></TR></TABLE>
That makes no sense at all and it's pretty obvious you have no idea what you are talking about.
There are a lot more factors involved in how long an engine will last when it's boosted...
Tuning is probably #1.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr 00 0108 »</TD></TR><TR><TD CLASS="quote">
Tuning is probably #1.</TD></TR></TABLE>
so ur telling me the more boost you run the longer a stock motor is going to hold up? THAT makes no sense at all
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr 00 0108 »</TD></TR><TR><TD CLASS="quote">That makes no sense at all and it's pretty obvious you have no idea what you are talking about.
Sarcasm is a wonderful thing, and most supercharger kits come with universal engine management mods that aren't tuned well enough to any specific application to guarantee any sort of long term reliability.
Exactly Kendall....but I didn't mention anything about using a universal engine management....my mistake.
If one doesn't take tuning seriously, it's the end of the motor. That means getting an engine management that knows what they're doing...i.e. Hondata or AEM EMS.
so ur telling me the more boost you run the longer a stock motor is going to hold up? THAT makes no sense at all </TD></TR></TABLE>
Nope, I never said that. Let's all get back to the real world here....you can't boost a stock engine to high Heaven, that's almost a "no need to say" statement, errr at least I thought it was.
The most important thing when boosting a motor (yeah yeah, within reasonable PSI standards) is tuning.
You seem to be stressing on PSI...I'm stressing on tuning because of people who don't bother to do it right and then blow up their engine on 8 psi....then they come back to boards like this and go "I blew up my engine on 8 psi." Then everyone jumps on the bandwagon and goes "you can't boost your engine to 8 psi." You never hear the other half of the story.
it depends on several things..
1. first.. condition/age of your car/motor.. everything is a wear item and how much hp you want to run. a boosted application that kept in low 200's on stock itr can be very reliable in my opinion.
2. if you pass on that, then you need proper fuel managment and good tuner, and just quality and reliability of parts that will make your setup work.
3. now, if you happen to get everything working well, the rest depends on your mad driving skills and keeping up with maintainance.
with all that said, go turbo.
nice numbers.
The jrsc uses an eaton m62 right? Is 10psi fine for the m62? I heard from magnusen that 6-7psi was it's optimal operating range. I don't have any experience with the jrsc, so I'm pretty curious. Thanks in advance for the help/info.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scoobydoobie »</TD></TR><TR><TD CLASS="quote">nice numbers.
The jrsc uses an eaton m62 right? Is 10psi fine for the m62? I heard from magnusen that 6-7psi was it's optimal operating range. I don't have any experience with the jrsc, so I'm pretty curious. Thanks in advance for the help/info.</TD></TR></TABLE>
i, personally, wouldn't go above 8.. technically, anything over the original pulley can mess up the supercharger, but I've seen quite a few 8 psi setups with no problems and lots of miles racked up..
JRSC is fine on an ITR, as long as you tune it properly. Engine management is KEY..
RippSpeed
Oct 13, 2008 09:22 PM
DC5AM
10
Jan 23, 2005 09:23 AM
