What are the Handling Characteristics of the ITR
Old Oct 4, 2001 | 07:26 AM
CPR's Avatar
CPR
Default What are the Handling Characteristics of the ITR
In it's most stock form, does the USDM ITR tend to oversteer, understeer, or feel nuetral? I say USDM because I believe there's some differences, when it comes to parts that are involved in handling, between the USDM and JDM.
I was wondering because I'm interested in the effects of adding the JDM rear upper strut tower bar. If I add this, how will it changed the handling? TIA
Old Oct 4, 2001 | 07:27 AM
AdamITR's Avatar
Default Re: What are the Handling Characteristics of the ITR (CPR)
Understeer
Old Oct 4, 2001 | 07:29 AM
DutchITR1689's Avatar
And lift throttle oversteer....
Old Oct 4, 2001 | 07:37 AM
travis's Avatar
Default Re: What are the Handling Characteristics of the ITR (EuroITR1689)
In my experience, the R tends toward oversteer at high speeds and understeer at low speeds. For example, in long, sweeping turns, it is possible to rotate the rear end with just a small breath off the throttle. In low speed sharp turns, it can be difficult to rotate the car as it tends to plow, so you have to really stick to the slow-in-fast-out mantra or you'll scrub too much speed too late. As for the strut bar, in the rear it will help (only help, and only a little) rotate the rear end and lessen the understeer. Nothing drastic.
Old Oct 4, 2001 | 07:39 AM
Big Phat R's Avatar
Understeer.
The rear strut bar won't do much btw - kind of a bling bling piece if you ask me. If you really want to stiffen the chassis noticeably - go with a weld-in cage or even a 4-pt roll bar.
Old Oct 4, 2001 | 08:38 AM
CPR's Avatar
CPR
Default Re: What are the Handling Characteristics of the ITR (Big Phat R)
Thanks Guys. So scratch the JDM strut bar for my ITR. How about a thicker rear stabilizer bar? Will this be a better investment in trying to make my car more neutral?
Old Oct 4, 2001 | 09:13 AM
Big Phat R's Avatar
I would say yes to that question.
Spartanic
Mar 24, 2004 06:13 AM
RATEDR
Jul 31, 2003 11:01 AM
Understeer
Oct 4, 2002 10:37 AM
RC211V
Apr 5, 2002 02:14 AM
