FS TONS TURBO STUFF PARTING OUT TURBO H22 CIVIC testing waters
im decided to part the car out im moving and have no room for it this stuff is all and need to sell everything
h22a1 motor $2700
block is auto race engineering sleeves
10:3.1 comp ceramic coated teflon skirts JE custom pistons
eagle rods upgraded rod bolts
1/2 inch custom ARP HEAD STUDS Machined to fit this block
balance shafts deleted
pro drive oil pump
h22a4 alluminum oil pan taped for turbo
completely built bottom balanced and blue printed
comes wit new h22 timing belt in the bag
water tube everything behind the plastic cover
brand new h22a1 crank pully i just spent 118 bucks for it
this pic is before the pistons were coated will have new pics soon
all motor work done by bob norwood in dallas TX
Spearco twin core air to liquid intercooler 3in inlet/outlet $565 with brackets
Precision 1000cc injectors $260
STR polish fuel rail line bored to fit msd 96lb injectors 110 shipped
h22 new starter make offer
92-95 civic AC AUTOTECHNIC rear lower tie bar new in the box $70
h22 injector resistor boxes have 2 $30 each
odb2 to obd1 coversion harness $85
Energy Suspension Master kit for a 92-95 honda civic complete brand new in the box $115.00
jaz 3gallon water cell $65
and water pump for intercooler $90 comes with all hoes and fittens
and disapater$65
CNC polished Hand brake or staging brake $110
H22 stock fly wheel just resurfaced $65
Accord intermediate shaft for a civic prelude swap use tegra axles with this $85 each i have 2 .
full-race h22 manifold with racegate flange brand new $975
BRAND NEW IN THE BOX
SC-61 t350 exhuast .60a/r decided not to use this one im using another one ill sell with the brand new return flange and inlet fitten all togther for what i paid for it
680 brand new
down pipe included with 3inch on center housing flange $150
precision garret t4 on center housing new .81 trim $140
areomotive fuel pressure regulator 6an with gauge 119.00
Aeromotive Fuel Filter 10an in and out $55
Moroso catch can $60
greddy type r bov with horn brand new $180 horn $45 together for $220
turbonetics racegate 46mm brand new $320 comes with dump tube also
PENDING<U></U>
other stuff not on car
polish valve covers one goes with each head not sold seaperately
h22a1 block complete bottom end $520 plus shipping will cod charge to you
stock and all there complete bottom end
have both timing and balancer belt
h22a4 crank and end caps and main caps all parts to a bottom end for a h22a4 block $280
aeromotive fuel filter $60
twin turbo supra fuel pump on a civic rail 65
paxton 1000 hp fuel pump $250
brand new BOGART dragon fly star wheels 15inch x 9 inches wide offset to fit factory civic suspension with hoosier 26x10x15 will trade for 13s with 25s on them and money $650 for 26s and tires
selling the shell of the car
it has
set up for h22 with shifter assembly
rear disks and front with accord hubs for strenghten axles
brand new paint job never started or driven car
gas tank is sumped and all ss lines ran under car for pump in rear of car aeromotive 1000hp fuel pump and filter
8an and 6an lines ran
26x10x15 hoosier slicks never used still have the nipples on there
lots more i will have more pics up of everything soon lots of parts
more pics of the enginebay but old when i was assembling
pics of the full-race manifold brand new
this is when i just drop motor in i will have more pics updated of finish product
email me for more info
Modified by h22civic2 at 9:08 PM 2/18/2004
Modified by h22civic2 at 9:49 PM 2/20/2004
h22a1 motor $2700
pro drive oil pump
and disapater$65
680 brand new
PENDING<U></U>other stuff not on car
it has
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMH22HATCH »</TD></TR><TR><TD CLASS="quote">Wow, great setup. Bob does some excellent work. How much for the manifold, wastegate, and downpipe? I'm located in DFW. Thank you.
Brandon</TD></TR></TABLE>
make me a resonable offer its brand new only ran on the dyno
wheels are not included i sold those allready but i do have a brand new set of
rota circuit 8 gunmetal with polish lip new in the box 16 inch
email me for qoutes and make me a resonable offer ill let you know yes or no
blemoine02@aol.com
radiator 235.00 with out fan 275 with fan
blemoine02@aol.com
email me and make me a resonable offer and the block has eagle rods upgraded rod bolts 1/2 arp head studs and rest i listed above just to update what i forgot
its a gt42 garret turbofrom geoff at full-race and made it to the tuning shop to finish wiring and made 2 passes on dyno but only made one power pull of 9psi at 380 whp but i was going to push it to around 600hp+ it will hold that if not more its garreenteed to make that ive built bunch of them and this one is way stronger than anyother than i built before
Your IM's are disabled, but if you can hit me up on AIM -- bbudd94gsr or email me @ bbudd94gsr@hotmail.com. Thanks.
Brandon
Brandon
b18bturbo what you mean a whole the whole car and motor and everything hit me up a email ill let you know that would be fine too but let mek now before i start breaking it down and it has a motec m4 pro on it right now but may not sell that
viren email me your num k and well talk i have peopl want the block and wastegate and bov all ready and others wanting the head and other motr but nothing sold yet will to sell car as but want to part out i need some stuff left on the car but not much
will TRADES FOR B-SERIES LOOKING FOR
MSD digital 6
full-race mani with a/c
dss axles
tilton clutch
wilwood brake kit
gsr head built or stock
gsr block built or stock
gsr tranny quife or stock
working on a brothers car and he need this reasonable trades
MSD digital 6
dss axles
tilton clutch
wilwood brake kit
