Body roll on 93 ex accord 2door?
Old Jan 27, 2004 | 03:00 PM
onewisepunk's Avatar
Default Body roll on 93 ex accord 2door?
Anyone know of stiffer sway bars or a good spring set up? I'm using Tokico blue shocks, and Tokico 1.2 drop springs, BUT I still have a lot of body roll.
Old Jan 27, 2004 | 03:02 PM
Riceburner247's Avatar
Default Re: Body roll on 93 ex accord 2door? (onewisepunk)
Just upgrage your sway bars, front and rear.
Old Jan 27, 2004 | 03:11 PM
Default Re: Body roll on 93 ex accord 2door? (riceburner247)
right.... but do you know who makes some, or one that will fit??
Old Jan 27, 2004 | 04:06 PM
jwogen1's Avatar
not familiar with the 4th gen suspension, but i would try suspension techniques...i know there is one that will fit
Old Jan 27, 2004 | 04:35 PM
LookingForVTEC's Avatar
wheels and a low profile tires. Just a thought!!
Old Jan 27, 2004 | 04:37 PM
jwogen1's Avatar
strut tower bars front and rear can help as well..
Old Jan 27, 2004 | 04:42 PM
Spider Man's Avatar
I happen to have a 93 coupe too.
Get your *** a strut bar.
It is DAY AND NIGHT.
shocks and srpings are not the way to go to get rid of the body roll.
That chassis flexes too much.
I put in one tower front strut.
WOW.
I'm on stock shocks and springs and body roll reduced DRAMATICALLY.
get a strut.
Old Jan 27, 2004 | 05:53 PM
spankey167's Avatar
Default Re: Body roll on 93 ex accord 2door? (Spider Man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spider Man &raquo;</TD></TR><TR><TD CLASS="quote">I happen to have a 93 coupe too.
WOW.
get a strut.</TD></TR></TABLE>
Sorry bro... strut bars don't do much if anything...Ask anyone that really knows suspension. They'll tell you to wait on struts and tell you to grab sway bars. Get sways like the others said. I've got ST sways on my 4th gen. And GOOD spring setup with good shocks will prevent body roll as well. As long as the spring rates are stiff enough. Another mod you might want to think of for body roll would be getting polyurethane bushings. Strut bars and tie bars would prob be the last suspension mod you would want to get.
Old Jan 27, 2004 | 06:38 PM
Nick H's Avatar
New User
Default Re: Body roll on 93 ex accord 2door? (spankey167)
a good suspension setup will have everything from springs/shocks to sway bars, to strut tower and lower braces...if you wanna go ***** to the wall then a roll cage and seam welded chassis is the next step...
Old Jan 27, 2004 | 06:43 PM
Spider Man's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spankey167 &raquo;</TD></TR><TR><TD CLASS="quote">
Sorry bro... strut bars don't do much if anything...Ask anyone that really knows suspension. They'll tell you to wait on struts and tell you to grab sway bars. Get sways like the others said. I've got ST sways on my 4th gen. And GOOD spring setup with good shocks will prevent body roll as well. As long as the spring rates are stiff enough. Another mod you might want to think of for body roll would be getting polyurethane bushings. Strut bars and tie bars would prob be the last suspension mod you would want to get. </TD></TR></TABLE>
Well you are entitled to your opinion.
But I have modded suspension on a few hondas and struts help alot.
I even took struts out of a few hondas for kicks.
Body roll city.
firm suspension is good, but chassis flex is the cause of body roll.
considering the price of a strut, it is the cheapest option to gain a considerable reduction in body roll.
Old Jan 27, 2004 | 07:12 PM
EGPrelude's Avatar
Body roll city.
considering the price of a strut, it is the cheapest option to gain a considerable reduction in body roll.</TD></TR></TABLE>
just to clarify for others, i believe he means strut "bars" and not struts as in shocks
Old Jan 28, 2004 | 09:42 AM
Default Re: Body roll on 93 ex accord 2door? (EGPrelude)
I DO have strut bars already, so.... I think the bushing upgrade and some sway bars will be the next step....
Thanks guys!
Old Jan 30, 2004 | 12:20 AM
[QUOTE=Spider Man] .....but chassis flex is the cause of body roll.QUOTE]
prove it.
Old Jan 30, 2004 | 02:06 AM
azian21485's Avatar
body flex only contributes a small amount to body roll if any...when you turn all your weight is transferred to the outter side of the car which causes your springs to compress...if you get stiffer springs and good shocks it will reduce body roll...swaybars will help even greater but too big of a bar will cause a loss in traction
strut bars and tie bars only reduce chassis flex keeping the body more stable
aZnPIGbOi
Aug 2, 2006 08:16 PM
machosos
Suspension & Brakes
Oct 19, 2005 11:31 AM
DownhillSpecialist
Suspension & Brakes
Aug 19, 2005 07:32 AM
EJ8 GSR-T
Suspension & Brakes
Jul 20, 2005 10:51 PM
kevinm1981
Jan 27, 2004 05:23 AM
