tach lead on a 95 DX
Old Jan 27, 2004 | 02:24 PM
fitbmx86's Avatar
Default tach lead on a 95 DX
so im installing a Tach on my DX, i got it all mounted, and wired for the light and stuff, but i have no idea where the tach lead is.... it says to the negative wire on the ignition coil. but i thoguht there would just be a tach lead somewhere in the dash? help please!!!!
Old Jan 27, 2004 | 03:04 PM
2lua's Avatar
Default Re: tach lead on a 95 DX (fitbmx86)
the blue wire that has a black rubber plug on the drive side shock tower. you can splice into that for your tach. signal.
Old Jan 27, 2004 | 03:05 PM
B18CivicEJ's Avatar
look at the drivers side of the firewall. there are 2 plugs to the left of the prop lever for the hood right along the firewall. there is a single blue wire alone on one plug. that is a tach wire.
Old Jan 27, 2004 | 04:43 PM
fitbmx86's Avatar
Default Re: tach lead on a 95 DX (B18CivicEJ)
so it is just one single wire, on one single plug? cause i didn;t see it, i saw a few plugs, and there were like 2 blue wires, one with a gray stripe and one with a white one, they were right next to each other. i wish somebody had a pic or something.
Old Jan 28, 2004 | 04:47 PM
fitbmx86's Avatar
bump.... come on somebody must know!!! i need this thing to be installed soon!
Old Jan 28, 2004 | 05:48 PM
92civeg's Avatar
Default Re: (fitbmx86)
its the blue wire in the harness next to your master cylinder
esean93
Aug 23, 2008 10:33 AM
E.F.Honda
Apr 24, 2008 05:07 AM
m2s4drespecial
Honda Civic (2001 - 2005)
11
Apr 5, 2007 08:11 AM
OutLuDeD
Mar 2, 2003 02:09 PM
yusoslo
Feb 22, 2003 07:05 PM
