Scatching 3rd gear in B16A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 »</TD></TR><TR><TD CLASS="quote">you're grinding in 3rd? need new synchros.</TD></TR></TABLE>
most likely
most likely
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elevatethis »</TD></TR><TR><TD CLASS="quote">or new mounts.....my 3rd gear synchro is fine but when i shift fast from 2nd to 3rd @ high rpm the motor moves and i grind</TD></TR></TABLE>
Same here...
Same here...
before you go swaping out trannies try this first
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 976 »</TD></TR><TR><TD CLASS="quote">Use search, GM syncromesh could own you... Read up!</TD></TR></TABLE>
alright, i have this problem, and so does %55 of the honda community. i plan on fixing it in my integra, it's a horrible grind, and i was told synchro this and that, but then i was told that i can't just get a synchro, that i have to get the gearset? can anybody clear this up?
Used it in my Lude. Made a world of difference.
I had the same problem (JDM B16) and It was a broken clutch disc. I changed the clutch and goodbye to the anoying 2-3rd gear scratch...
-ben
-ben
yeah you have to order them as 1-2 gear set 3-4 gear set, or something like that. anyone else think it could be a bad shifter fork? i've heard that will cause some grind going into gear.
i've heard gm synchromesh does wonders.
Mikey3000
Sep 24, 2007 08:17 AM
