leaking power steering fluid...
Old Jan 27, 2004 | 11:21 AM
NoLipRacen's Avatar
Default leaking power steering fluid...
about 2 months ago i removed my power steering belt and just today i noticed that it is leaking fluid from the resevoir. there is actually a pool of it forming under the driverside quarter panel in front of the wheel. what is the cheapest/easiest way i can fix this (i dont care if i do or dont have p.s.) i do still have the belt in case youre wondering. thanks in advance
Old Jan 27, 2004 | 11:23 AM
laughinxxx's Avatar
New User
Default Re: leaking power steering fluid... (LudeTuner)
Is it leaking from a crack in the reservoir, is the tube from the reservoir cracked, is it lose, etc.? If it is the tube I'd just replace it. If it the reservoir go to a junkyard and get one for cheap.
Old Jan 27, 2004 | 11:41 AM
sambam27's Avatar
i have the same problem right now. i was turning my wheel while it was on ignition and when i was looking, power steering fluid was gushing out while i was turning it. it happened out of no where and theres no cracks on the resevoir. does anyone know whats up with it?
Old Jan 27, 2004 | 11:49 AM
laughinxxx's Avatar
New User
Default Re: (PreLudexSi)
That's like saying "I'm losing oil between oil changes, where is it going?" You could be burning it, bad cam seal, bad main seal, etc. Figure out exactly where the PS fluid is coming out of. Then you will be able to get some help.
Old Jan 27, 2004 | 12:06 PM
NoLipRacen's Avatar
Default Re: (laughinxxx)
what is the easiest way to figure it out? turn the car on and see where it comes from or what?
Old Jan 27, 2004 | 04:11 PM
laughinxxx's Avatar
New User
Default Re: (LudeTuner)
Turn the car on, get one person to turn the wheel, and another to watch for fluid.
kjrayo18
Feb 11, 2013 02:43 PM
Kavehman
Sep 5, 2005 04:14 PM
sysconx
May 19, 2004 09:28 AM
nek0
Sep 25, 2003 08:06 AM
