Things to do before I go to my Tuning session at DSR??
My car is FINALLY getting tuned tomorrow after all the hassle from gathering parts
...I want everything to be perfect, so today Im doing a fresh oil change, checking spark plugs, and topping off all fluids....is there anything else i should do...thnx guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 »</TD></TR><TR><TD CLASS="quote">what kind of tuning? VAFC? Hondata? EMS? general cam and timing?</TD></TR></TABLE>
hondata s200, cams etc....
clean your air filter, check your tire pressure, get there early to allow your car to cool off a little, run the correct octane in your car...think that you have everything set then...
Austin
Austin
RESULTS ARE In!!!...need someone to post my graph!!!......I hit 180whp/130torque....but i gained 27whp between 53000rpm-7500rpm...i was kinda looking for some high numbers but atleast I have a good solid midrange...Looks like i need a better header, and exhaust....I'll probably be looking for some stage 2's now...Graph will be up soon as soon as i find someone to host it
good numbers man. Post that graph. I want to see how healthy that midrange is. Screw the peak number, mid is what you feel.
Lifter2012
Jan 17, 2006 03:34 PM
A hungry tuner is never at his full potential.
