D15B1 mini swap z6 heads
Old Jan 27, 2004 | 08:07 AM
rebohn's Avatar
Default D15B1 mini swap z6 heads "89 hacthback"
i have project mini swap b1 engine z6 will fit ? works good ? heads,manifold sensors and distributor gaskets? please help if works this swaping in b1 block
other question where i can get a rpm switch? instruccion of installation?
Modified by rebohn at 9:20 AM 1/27/2004
Old Jan 27, 2004 | 08:14 AM
Snail Tuning's Avatar
Default Re: D15B1 mini swap z6 heads (rebohn)
helping a friend out.
89 civic coupe, with D15b1 so im assuming its the same as our usdm DX engine.
engine is obd0 and is from a canadian version car.
the car only has 2 injectors so im gessing he will need to upgrade to mpfi, so could he use an SI harness, manifold, and injectors on the z6 head? and then just use a RPM switch to activate Vtec?
also will the obd0 dizzy bolt up?
Old Jan 27, 2004 | 08:21 AM
rebohn's Avatar
Default Re: D15B1 mini swap z6 heads "89 hacthback" (rebohn)
i can upgrade the mpfi z6 manifold?
Tw1n Turb0 Z
33
Oct 8, 2006 10:19 PM
Drew17th
Jun 1, 2006 07:18 AM
e30dood
Oct 26, 2003 07:44 PM
