1999-2000 Civic Si Wheels on my 99 EK
Old Jan 27, 2004 | 07:54 AM
Smith Wise's Avatar
Default 1999-2000 Civic Si Wheels on my 99 EK
Maybe I'm just retarded or something.
I'm late for work right now, so I was trying to rush to do this before 12:00. I couldn't get the back wheels to lay flush against the drums so i could tighten them with the lugnuts. I have aftermarket lugnuts so i think I'll have to try it with some oem lugnuts later.
I was expecting to just run do there and throw them on in about ten minutes, but I never could get the back ones to lay flat against the drums. it seemed like there was a gap between the back of the wheel and the drum. never tried the front ones, didn't have time.
Anyone have any similiar issues?
probably not, oh well.. I'll try again tonight when i get off.
Old Jan 27, 2004 | 07:56 AM
1badda's Avatar
never had that issue
Old Jan 27, 2004 | 08:02 AM
Ricey McRicerton's Avatar
Default Re: (streetaccord)
They fit fine on my car....
Old Jan 27, 2004 | 08:06 AM
chameleon's Avatar
Default Re: (Ricey McRicerton)
most important thing is see how they lay when the lugnuts are tight not before tightening.
Old Jan 27, 2004 | 08:07 AM
SloCivicHMM's Avatar
Default Re: (chameleon)
they should fit unless your drum has something sticking out of it.....hmm that wierd, all honda wheels are interchangeble assuming the lug pattern is the same...
Old Jan 27, 2004 | 08:18 AM
Smith Wise's Avatar
Default Re: (SloCivicHMM)
there is a blue ring around all the axle nuts that is preventing the wheels from going on, it lays flush against that ring, preventing it from reaching the face of the drum...
Old Jan 27, 2004 | 08:21 AM
JforJonathan's Avatar
Default Re: 1999-2000 Civic Si Wheels on my 99 EK (Jswpstdoff)
thats weird...they should fit fine.
Old Jan 27, 2004 | 08:22 AM
sil's Avatar
sil
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jswpstdoff &raquo;</TD></TR><TR><TD CLASS="quote">I have aftermarket lugnuts so i think I'll have to try it with some oem lugnuts later. </TD></TR></TABLE>
use OEM lugnuts
Smith Wise's Avatar
Default Re: 1999-2000 Civic Si Wheels on my 99 EK (Dj Villain)
going to take pics...
Old Jan 27, 2004 | 08:45 AM
2lua's Avatar
what kinda wheels you had on it before? perhap the blue ring could be a spacer for your old wheel?
Old Jan 27, 2004 | 08:47 AM
Smith Wise's Avatar
here are the pics...
these are my 14" wheels still on the car with the blue ring sitting inside of the circular opening...
the infamous blue ring
a side shot, sticks out just far enough to keep my si wheels off
this is a pic of the back of my 14" wheels, wide opening that fits over the blue ring
the si opening is smaller and does not fit over it
once again, these wheels do not fit over this blue ring
i was also thinking that oem lugnuts would be better but... i can't get the wheel on, so lugnuts aren't an issue yet. i'm an hour late for work. if you guys get any ideas please post them. i'll be back online around 8:00
Old Jan 27, 2004 | 08:49 AM
Smith Wise's Avatar
Default Re: 1999-2000 Civic Si Wheels on my 99 EK (2lua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua &raquo;</TD></TR><TR><TD CLASS="quote">what kinda wheels you had on it before? perhap the blue ring could be a spacer for your old wheel?</TD></TR></TABLE>
it doesn't look like it can be taken off..
Old Jan 27, 2004 | 09:14 AM
Buzzbomb's Avatar
That is what's called a hubcentric ring and it's suppose to come off. They get kinda ceased on there and it will take some work to get them off.
Old Jan 27, 2004 | 09:19 AM
madturns's Avatar
they should bolt right up
Old Jan 27, 2004 | 09:20 AM
Targa250R's Avatar
be professional
Default Re: 1999-2000 Civic Si Wheels on my 99 EK (Buzzbomb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buzzbomb &raquo;</TD></TR><TR><TD CLASS="quote">That is what's called a hubcentric ring and it's suppose to come off.</TD></TR></TABLE>
Old Jan 27, 2004 | 09:29 AM
EKhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buzzbomb &raquo;</TD></TR><TR><TD CLASS="quote">That is what's called a hubcentric ring and it's suppose to come off. They get kinda ceased on there and it will take some work to get them off.
What wheels were on there before?
Old Jan 27, 2004 | 10:21 AM
Smith Wise's Avatar
Default Re: 1999-2000 Civic Si Wheels on my 99 EK (EKhatch)
on my lunch break...
you guys are a big help...
i talked to my boss, he's kind of a ricer, and he told me that the ring should probably come off but will be a PITA...
thanks for the help once again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKhatch &raquo;</TD></TR><TR><TD CLASS="quote">
What wheels were on there before? </TD></TR></TABLE>
nothing special... 14" American Racing wheels... i bought them b/c they were cheap as hell and easy to clean... needed new tires since these are about 20 months old... found some local guy selling his si wheels for $300... couldn't pass that up...then talked him down to $250 for one odd tire, and having to drive so far to meet with him
Old Jan 27, 2004 | 10:22 AM
Smith Wise's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jswpstdoff &raquo;</TD></TR><TR><TD CLASS="quote">here are the pics...
this looks like it's going to be a PITA
Old Jan 27, 2004 | 10:37 AM
akeldama's Avatar
Yep, hubcentric ring for aftermarket rims. Just yank the **** out of it.
Old Jan 27, 2004 | 12:07 PM
Austinbionic316's Avatar
Default Re: 1999-2000 Civic Si Wheels on my 99 EK (EJ1)
Question...since I have the 96-98 Civic EX couldnt I put the Si rims on my car as well?
Old Jan 27, 2004 | 12:15 PM
RacerXI's Avatar
Default Re: 1999-2000 Civic Si Wheels on my 99 EK (Austinbionic316)
Get yourself a screwdriver and a hammer. If that doesn't work, use a bigger hammer.
Old Jan 27, 2004 | 12:26 PM
Spade's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austinbionic316 &raquo;</TD></TR><TR><TD CLASS="quote">Question...since I have the 96-98 Civic EX couldnt I put the Si rims on my car as well?</TD></TR></TABLE>
Yes
Old Jan 27, 2004 | 12:31 PM
Default Re: 1999-2000 Civic Si Wheels on my 99 EK (Spade)
thanks
Old Jan 27, 2004 | 01:10 PM
Evs-One's Avatar
Solbros Owns Me
funny stuff.....just hit the ring with a screwdriver and hammer evenly around the ring until it starts to come off
ShinsenTuner
Hawaii & Asia-Pacific
Apr 29, 2015 11:58 AM
anstitute
Aug 21, 2010 12:02 PM
Aventuraa
Jul 31, 2010 01:15 PM
Davidss
Aug 14, 2007 08:42 PM
daft
Jul 14, 2004 10:54 AM
