Driverside window install??
Old Jan 27, 2004 | 05:54 AM
photec2's Avatar
Default Driverside window install??
well my stock hatch got broken into and they took my $50 wal-mart special CD player Damn kids. oh well but they broke my driverside window and im getting one for $65 at the junkyard. soo how do i put it in?? any little tricks i need to know?? TIA
-Brandon
Old Jan 27, 2004 | 06:03 AM
doublejz's Avatar
Default Re: Driverside window install?? (photec2)
just take off your door panel. and remove the plastic (that is if nobody has before, and forgot to put it back on), put the window about half way down (theres like only 1 place where you can get access to the bolts), there are two bolts that hold the window to the track. Get a rachet and an extension take them out. Pull the window out and put the new one in. Make sure you get the window lined up right, both sides have a groove the whole way. put it in there, then put the two bolts back in.
Old Jan 27, 2004 | 06:07 AM
photec2's Avatar
Default Re: Driverside window install?? (doublejz)
cool thanks a lot
Old Jan 27, 2004 | 07:33 AM
Newman's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">just take off your door panel. and remove the plastic (that is if nobody has before, and forgot to put it back on), put the window about half way down (theres like only 1 place where you can get access to the bolts), there are two bolts that hold the window to the track. Get a rachet and an extension take them out. Pull the window out and put the new one in. Make sure you get the window lined up right, both sides have a groove the whole way. put it in there, then put the two bolts back in.</TD></TR></TABLE>
Pretty much . Just had to help out my co-worker's car yesterday with the same exact thing. Just one more thing to add, when dropping the glass in, make sure that you get the glass on the correct side of the rubber stoppers by the door handle. If you don't slide the glass behind it, and try to roll it up, it'll get stuck and be ultra hard to wind up and down.
acc0rdf22
Oct 8, 2009 12:17 PM
JDMgunmetalCRX
Mar 31, 2009 08:50 AM
conan4
Nov 9, 2008 04:47 PM
deconstruct
Mar 1, 2005 05:41 PM
XEF-9X
Feb 19, 2003 05:20 AM
