dc5r wing thing
Old Jan 27, 2004 | 05:32 AM
ekferio's Avatar
Default dc5r wing thing
i went to retighten the cap nuts under the trunk and broke one of the studs off the type r wing (the real one). Are mounting on 3 screws ok? i don't think it will fall off with 3 screws & tapes but just want to make sure
Old Jan 27, 2004 | 07:51 AM
Hooligan317's Avatar
Default Re: dc5r wing thing (ekferio)
you should be fine... suxors though
Old Jan 27, 2004 | 09:36 AM
GreenBean's Avatar
Default Re: dc5r wing thing (Hooligan317)
Are those threads into the wing also, I know they only get tighteneed down to like 12ft/lbs. Not much at all...If it was a rearward bolt I'd say its ok...If its a front bolt. You may try and find a way to secure it. Like the aftermarket wings that the bolts go into the threads in the wing.
Old Jan 27, 2004 | 09:56 AM
ekferio's Avatar
Default Re: dc5r wing thing (GreenBean)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenBean &raquo;</TD></TR><TR><TD CLASS="quote">Are those threads into the wing also, I know they only get tighteneed down to like 12ft/lbs. Not much at all...If it was a rearward bolt I'd say its ok...If its a front bolt. You may try and find a way to secure it. Like the aftermarket wings that the bolts go into the threads in the wing.</TD></TR></TABLE>
what are rearward bolts and front bolts?
Old Jan 27, 2004 | 10:08 AM
there are two bolts on each side of the wing right? one towards the front of the wing, and one towards the rear... so the two (one on each side) that are toward the front of the wing are the front bolts, and the other two (closest to you) are the rearward
Old Jan 27, 2004 | 10:14 AM
ekferio's Avatar
ooh...all 4 threads are off the wing itself unlike the USDM one
and it's the one on the rear that's broken
Old Jan 27, 2004 | 10:17 AM
thats cool, you should be fine man
trevorjohn88ef
44
Jan 7, 2008 06:14 AM
bhornback10
Nov 18, 2004 12:56 PM
AzN_Flava
Feb 21, 2004 10:18 AM
droppedcivo
May 2, 2003 01:27 PM
ActiveAero
Mar 7, 2002 08:31 PM
