Eibach Springs w/ Koni Yellow Adjustables
Old Oct 3, 2001 | 08:58 PM
Keyed ITR's Avatar
Default Eibach Springs w/ Koni Yellow Adjustables
Is anybody running this setup...Sportlines or Pro kits. What's your opinion on them, are they better than a full coilover setup like APEX'i N1, Tanabe Sustec Pro SS etc. Also, is it true that it lowers it 3/4 of an inch too...
Thanks in advance.
Old Oct 24, 2001 | 01:31 AM
ToneyTigre's Avatar
New User
Default Re: Eibach Springs w/ Koni Yellow Adjustables (Keyed ITR)
if i had to do it all over again, i'd go with a complete damper set up like apexi coil overs. it costs about the same. or the koni coilover set up.
Old Oct 24, 2001 | 01:44 AM
nEoMuGen's Avatar
I heard H&R Stage 2 are better than Eibach. Although H&R may require a camber kit for its 1.75 inch drop.
For a bargain adjustable setup, H&R/KYB AGX is a good setup, pay $200 for Koni Yellow is even better.
Old Oct 24, 2001 | 05:13 AM
BoM's Avatar
BoM
Default Re: Eibach Springs w/ Koni Yellow Adjustables (nEoMuGen)
I consider Eibach and H&R to be two of the top Spring Companies
both of them make streetable high performance suspension parts
can't go wrong either way.
a full coilover system is the best though
fully adjustable and it emptys your wallet for some time]
with the price of KONI's being 500 a set
and a pair of springs 200-300 your close to a price of full coilovers
get them. Since you got a type R, you dont' want to DISRUPT its
handling.
Old Oct 24, 2001 | 11:23 PM
Hacemuy's Avatar
does anybody have any pics of this set up?
Old Oct 25, 2001 | 12:22 AM
Rain_man's Avatar
New User
Default Re: Eibach Springs w/ Koni Yellow Adjustables (SOMEguyFROMoregon)
500 for the koni's and 150 for the sportlines, (not 200-300). Total of 650 versus koni coilovers for about 850. If you are talking about even higher end coilovers like zeal, tein and so on you're looking at least 1200-1500, which is alot more than the 650.
If you don't auto-x the full coilovers aren't worth it.
And you aren't going to ruin your car by going with lowering springs, just because it's a Type-R. It'll handle better, but at the cost of lowered ride height. I swear some people act like Honda sprinkled some magic pixie dust on ITR parts...
If you want to keep your stock ride height but want stiffer springs, I believe Eibach makes some non progressive springs.
DcLs
Suspension & Brakes
Jan 28, 2009 04:11 AM
IgnitionZ055
Suspension & Brakes
Oct 11, 2008 10:42 PM
guero2craze
Jan 13, 2007 10:12 PM
b18c4door
Oct 9, 2003 09:01 PM
Keyed ITR
Oct 24, 2001 05:07 AM
