93 Civic....Brake/Clutch Fluid Inside Car
Old Jan 26, 2004 | 09:54 PM
lo0nY's Avatar
Default 93 Civic....Brake/Clutch Fluid Inside Car
Redoing my alarm last night, anf found, brake fluid all over the place, I pressed down the clutch and i see a little bit of fluid coming out, from right above the pedal, anyone have any idea what the cause of this? and how could I fix it?
Thanks
Old Jan 26, 2004 | 09:58 PM
BauleyCivic's Avatar
Risky Business
Default Re: 93 Civic....Brake/Clutch Fluid Inside Car (lo0nY)
Probably a leaking seal on your master cylinder
Old Jan 26, 2004 | 10:00 PM
salbaje's Avatar
Default Re: 93 Civic....Brake/Clutch Fluid Inside Car (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">Probably a leaking seal on your master cylinder</TD></TR></TABLE>
yes you will need to replace your master cylinder. do not buy the rebuild kit as it will end up like that after some mileage
Old Jan 26, 2004 | 10:03 PM
lo0nY's Avatar
the brake master cylinder will cause the clutch to leak too?
Old Jan 26, 2004 | 10:56 PM
blueeg's Avatar
the brake master cylinder will not cause the clutch to leak. the CLUTCH master cylinder is whats leaking. the cluctch master cylinder uses brake fluid to operate.
Old Jan 26, 2004 | 10:57 PM
Echo7847's Avatar
They're referring to the Clutch Master Cylinder. It also uses brake fluid. Just get a new one, install isnt hard @ all, and they arent very expensive, should be &lt; $80
Old Jan 27, 2004 | 07:25 PM
lo0nY's Avatar
Default Re: 93 Civic....Brake/Clutch Fluid Inside Car (blueeg)
where is the clutch master cylinder located at?
Old Jan 27, 2004 | 09:11 PM
EvilPhu's Avatar
The brake fuild is coming from the shaft of the clutch master cylinder, it's connect to the clutch pedal, cause by bad seal. Replace the clutch master cylinder, it's around or next to the brake master cylinder, It's the one with the smaller resevior. Remeber to bleed the system after you change it, to get the air out.
Old Jan 27, 2004 | 09:16 PM
mike93eh
Guest
Posts: n/a
i just replaced my clutch master cylinder last week because it was leaking on the inside..no more leaks now.
Old Jan 28, 2004 | 11:33 AM
lo0nY's Avatar
is it like bleeding the brakes? or different?
Old Jan 28, 2004 | 11:42 AM
dunkd's Avatar
yah go buy new clutch master cylinder from honda, like $100 max. easy to do... pretty self explanitory to do.
Old Jan 28, 2004 | 11:56 AM
yellow_jacket's Avatar
Default Re: 93 Civic....Brake/Clutch Fluid Inside Car (dunkd)
pretty much the same as bleeding brakes. Just bench bleed it before you install it. After you install it there is a bleeder valve on the slave cylinder.
Old Jan 28, 2004 | 02:15 PM
mike93eh
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">yah go buy new clutch master cylinder from honda, like $100 max. easy to do... pretty self explanitory to do.</TD></TR></TABLE>
$85 @ hondaautomotiveparts.com
JDMswagSerf
Dec 10, 2013 09:47 PM
Zulu888
Jun 19, 2006 09:30 PM
itsJDMyo
Oct 24, 2005 05:02 PM
vtecdc2
May 20, 2003 07:27 AM
AJTEG
Jan 18, 2002 07:23 AM
