Plug and Play? SI harness + civic DX
Old Jan 26, 2004 | 08:40 PM
ITR981002's Avatar
Default Plug and Play? SI harness + civic DX
I'm swapping a B16a1 in my 91 dx hatch. The motor came with the SI harness for the injectors. I know the Green one plugs into a resistor box:
If I plug the white one into the harness on the car in this picture:
The DX harness on my car doesn't include the additional injector wires that the SI harness on the motor does right? So If I just plug that in, its not going to work. Is it easier just to modify my DX harness with the correct injector plugs and add the wires for the 2 new injectors or to somehow use the SI harness on the motor?
Old Jan 26, 2004 | 08:53 PM
BIG RICH's Avatar
Default Re: Plug and Play? SI harness + civic DX (ITR981002)
It's easier to modify the DX harness. I've been through it. I did it a while back for my ZC, then a friends ZC and now another friend with a b16a.
Old Jan 26, 2004 | 09:27 PM
Home Skillet's Avatar
Making the Si wire harness work is a big pain in the ding dong, but not impossible.
chadmasterc's Avatar
Use the dx harness, if you would have searched for 5 seconds you would have found your answer.
Old Jan 27, 2004 | 04:51 AM
Fobtions's Avatar
Default Re: Plug and Play? SI harness + civic DX (chadmasterc)
Si engine harness is gonna be 10x more difficult to adapt to your dx. just do the dx-mpfi conversion that the majority of people do using all the plugs that u got on the si harness accordingly.
Old Jan 27, 2004 | 06:14 AM
tilt's Avatar
on the b16, unravel the electric tape and plastic sheathing. Just use the green plug and all the wires that run to the injector plugs. hth
Old Jan 27, 2004 | 07:48 AM
ITR981002's Avatar
Default Re: Plug and Play? SI harness + civic DX (tilt)
Thank you, that does help!
efjones9
14
Nov 30, 2009 11:16 AM
knightsef-eg
20
Jan 2, 2009 01:51 PM
sasinorm01
May 27, 2008 02:44 PM
Argetnia
Apr 7, 2005 11:54 PM
elmalouno
Apr 26, 2004 02:35 PM
