CRX Squeeks??
Old Jan 26, 2004 | 08:13 PM
Robb's Avatar
Default CRX Squeeks??
having owned and driven several CRXs I have noticed they all have that annoying squeek coming from the back when going over bumps. Does anyone know the cause? Thanks.
Old Jan 26, 2004 | 08:46 PM
sabertooth's Avatar
pop the hatch. when u look at the bottom that sits on top of the tail light section u will see 2 rubber '*****'.these ***** have spiral cuts int them. these slots allow for the ***** to be 'tuned' in or out just as u would tighten or loosen a bolt. i would suggest turning the ***** as if u were tryin to take a bolt out. it wont cure the squeakin but it will definately decrease the noise
Old Jan 27, 2004 | 03:44 PM
SmobbinSi's Avatar
Default Re: (sabertooth)
Finally, after driving around with that squeek for nearly 15 years, I got irked enough to do something about the exact same issue you describe in your post Robb. I guess after hearing it for so long, my mind just blocked it out.
Oh well, the easiest and quickest fix is to put electrical tape around the "loop" that the hatch lock mechanism locks onto so that your hatch doesn't fly open while you're driving. Kind of hard to explain without a picture. Does it make sense though?
Old Jan 27, 2004 | 04:05 PM
crxgator's Avatar
Default Re: (SmobbinSi)
thats what i did too, electrical tape...
Old Jan 27, 2004 | 04:08 PM
EL Vap133's Avatar
Default Re: (crxgator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">thats what i did too, electrical tape... </TD></TR></TABLE>
Same here, works wonders and it very easy to do....
Old Jan 27, 2004 | 04:22 PM
HT Chaplain's Avatar
Loved
Default Re: (EL Vap133)
10 years of driving the CRX and now i know what to do HONDATECH
Old Jan 27, 2004 | 04:23 PM
EL Vap133's Avatar
Default Re: (legutki)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by legutki &raquo;</TD></TR><TR><TD CLASS="quote">10 years of driving the CRX and now i know what to do HONDATECH </TD></TR></TABLE>
Hey, sometimes Jesus takes a little long to answer prayers but he does....
Old Jan 27, 2004 | 05:06 PM
X-Static's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SmobbinSi &raquo;</TD></TR><TR><TD CLASS="quote">Finally, after driving around with that squeek for nearly 15 years, I got irked enough to do something about the exact same issue you describe in your post Robb. I guess after hearing it for so long, my mind just blocked it out.
Oh well, the easiest and quickest fix is to put electrical tape around the "loop" that the hatch lock mechanism locks onto so that your hatch doesn't fly open while you're driving. Kind of hard to explain without a picture. Does it make sense though?</TD></TR></TABLE>
my favorite cheap mod!
Old Jan 27, 2004 | 10:13 PM
Nature's Renewal's Avatar
Default Re: CRX Squeeks?? (Robb)
Oh man, I just bought my 89 crx si 2 months ago and that squeek in the rear has been driving me nuts. Thank goodness I didn't have to wait years to figure it out.
Old Jan 28, 2004 | 12:04 AM
The Ace's Avatar
Default Re: CRX Squeeks?? (krskid)
I already knew this solution, because the exact same thing was going on for all the time that I had my '92 Civic. Honda did a booboo when it decided to do a 2-part rear hatch.......
Anyway, indeed some electrical tape should fix it right up.........dont use too much though, because a) it wont lock as easily (or at all), and b) it will put more strain on the lock......
cbp_crx
Dec 10, 2004 10:22 AM
theemaddhatterr
14
Jun 6, 2004 03:33 PM
EL Vap133
15
Oct 24, 2003 08:27 AM
RicedREX
13
Jul 4, 2003 01:30 PM
gocivicgo
Jul 4, 2003 10:37 AM
