Fuel Pressure
Old Jan 26, 2004 | 06:48 PM
bigfatkrakr's Avatar
Default Fuel Pressure
Ok, I just installed a B&M Fuel Pressure Modifier on my civic and I don't know what pressure I should adjust my fuel to. I've heard from several people that I should go to psi under stock, my problem there being that I don't know what stock psi is. If someone could please tell me what that is, it would be greatly appreciated.
Thanks,
Sean
Old Jan 26, 2004 | 06:54 PM
Ricey McRicerton's Avatar
Default Re: Fuel Pressure (bigfatkrakr)
I think stock is somewhere between 40-44 at WOT. And I only helped you because you have the same name as I do.
Modified by Ricey McRicerton at 11:10 PM 1/26/2004
Old Jan 26, 2004 | 06:59 PM
dogfood's Avatar
Stock psi is 35-40 depending on where the throttle is at, 35 at idle. B&M should have given you a formula on how to figure out the new psi, it has to do with what mods you have, it came with mine.
Old Jan 26, 2004 | 07:08 PM
jazz215's Avatar
my guage shows mine at 32psi (at idle) most of the time my a/f guage shows im rich..then lean then rich then lean..heheh
Old Jan 27, 2004 | 08:11 PM
Micro's Avatar
yea, i just installed one too... and per instructions... it should be set at 48. Some of my freinds said to put it at 52 because of some of my mods.
Old Jan 27, 2004 | 08:15 PM
mike93eh
Guest
Posts: n/a
my stock fuel pressure is 34psi at idle..
Old Jan 27, 2004 | 08:22 PM
Quad-Damag's Avatar
Default Re: (mike93eh)
dam im 40 idel and 52 wot
Old Jan 27, 2004 | 08:24 PM
TwistedSI's Avatar
I believe mine is 40 at idle and like 45 WOT. Been a long time since I actually checked. I just got the gauge because it was cheap.
JdM_Eg6_SiiR
Jun 13, 2009 02:35 AM
SOFLSOL
Aug 14, 2003 02:03 PM
migo
Jul 7, 2001 10:43 AM
