How To Connect Small Wires To Battery?
Ive got some small things such as a wire from my StreetGlow Underbody neon kit that has a wire that on the install manual is supposed to go right to the battery. How do you guys attach these wires to your battery. I went to radioshack and looked around, couldnt figure it out I guess
their is probably a nice place in the fuse block that has some smaller connectors that you could tap from. Otherwise you can get the good clamps and do it from thos distribution blocks.
find out which wire is ground and which is 12 volts. be sure to add a fuse to the 12 volt wire cause if you short the wires theres a pretty good chance that your going to catch your car on fire...connect the ground to eaither the ground on the battery or ground it to the car...the 12 volt wire can be connect to the fuse box, or directly to the battery. be sure to test everythign with a multimeter.
under the hood...theyre should be a fuse box, and theyre are like either 2 10mm screws or 2 phillips crews that you can unscrew and bolt a wire up to. you'll see it cause connected to those screws theres a stock wire that runs to the 12v side of the battery.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by niccuhles »</TD></TR><TR><TD CLASS="quote">under the hood...theyre should be a fuse box, and theyre are like either 2 10mm screws or 2 phillips crews that you can unscrew and bolt a wire up to. you'll see it cause connected to those screws theres a stock wire that runs to the 12v side of the battery.</TD></TR></TABLE> that exactly. their should be a wire that runs right off the battery to a fuse block maybe 15 inches away, it will be under a cover in engine compartment. Thats where i tapped into for my amps.
A nice polished or plated terminal block looks good on top of a battery. They have a combination of small and large provisions for wire. Look into it!
I think compression fittings are the best for this. If you dont know what they look like you can check them out http://www.monstercable.com/ca....html
basically you can use one of the smaller fittings to put a bunch of little wires into instead of one big one.
c|rop3asy==[]
Sep 9, 2013 11:17 PM
redman223
Audio / Security / Video
May 4, 2007 02:51 PM
hb_guy
Apr 9, 2006 06:43 PM
