show car fixups
I live in arkansas and i was wondering if there was any place that would be good to completly customize my car. also i have air cylinders on my car and i dont know much about them but it is set up on 10 swithces and 4 are for each tire.
it was working fine but know the whole car just goes all the way up or all the way down and thats it . no more three wheel or front back side side. and once it is up it will slowly sink down. any solutions?
honestly i don't know of anyone on here that could help you, an overwelming about of people on here modifi there honda's for performance enhancments then the other small percent does mods that make there car look like the cars that have performance enhancments. i do belive that there is a member in the EF section that has rods/struts/bags on his civic. not sure on that
I guessing you are using a Swich Box , If only All up / All down is working you need to check the connections in the swich box and also at the valves.. As far as the leeks take some Windex and spray on all of the Fittings(if brass fittings) , tightn as needed. If the fittings are plastic you need to replace all of them with brass compression or they will always leek... Hope this helps
ek9grey
Apr 16, 2007 07:40 PM
jdmgood,usabad
25
Sep 10, 2004 03:31 AM
B18C5-EH2
Feb 17, 2002 06:26 PM
