88-89 and 90-91 civic hb different dashes?
are they setup differently? or is mine just not mounted right. the body metal peice that holds you radio ect. does meet and bolt up with the floor, wtf?
btw i have a 89dx with a 90si dash
where the cluster sits is different.
They will bolt into each other but the main difference is the curves. If you need a dash I have a 91 hb dash gray one that I dont really need. Comes with all wiring too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b17boost »</TD></TR><TR><TD CLASS="quote">
ill goto the junkyard and get a 89 dash
both dashes are similar but different. the hb mounts similar but the metal frame for the center console is slightly different. Along with around the dash cluster. I would use everything from the donor car to make it fit right. The center consoles share some differences because the on the crx the center console tapers over the shifter unlike the civic. It will bolt up the same but you will have that wierd gap on the floor.
JokerTypeR
Feb 3, 2008 07:35 AM
julioboostamante
Dec 7, 2007 04:57 PM
