Quick Question Regarding (parts from EG to EK)
Old Jan 26, 2004 | 11:58 AM
NINE TRE's Avatar
Default Quick Question Regarding (parts from EG to EK)
This is just for temporary purposes, because i need it for my stock car...
i have to replace my exhst manifold on my stock 97 CX motor. there is a cat built in the headers w/ 2 O2 sensors. Now, i have an offer from a guy who is willing to sell me his exhst manifold, downpipe, cat and midpip off a 92 cx... just wondering if this will fit on my ek? will it be ok with the ecu?
thanks
Old Jan 26, 2004 | 12:12 PM
NINE TRE's Avatar
Default Re: Quick Question Regarding (drunkn_tyger)
bump
Old Jan 26, 2004 | 12:15 PM
spnfed's Avatar
It will work, but you will need to add another O2 bung for the 2nd one, and lengthen the wiring.
Old Jan 26, 2004 | 12:16 PM
Ricey McRicerton's Avatar
It should fit, but you will have a CEL. There is no bung on the 02 for a secondary 02 sensor.
Old Jan 26, 2004 | 01:05 PM
slammed_93_hatch's Avatar
Default Re: Quick Question Regarding (spnfed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spnfed &raquo;</TD></TR><TR><TD CLASS="quote">It will work, but you will need to add another O2 bung for the 2nd one, and lengthen the wiring. </TD></TR></TABLE>
yep do what he said
Old Jan 27, 2004 | 07:09 AM
NINE TRE's Avatar
ic, so there is no way around to eliminating that second o2 sensor is there?
Old Jan 27, 2004 | 07:46 AM
chameleon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drunkn_tyger &raquo;</TD></TR><TR><TD CLASS="quote">ic, so there is no way around to eliminating that second o2 sensor is there?</TD></TR></TABLE>
if you add in a swap and use a OBD1 ecu you will not need that second o2, if you decide on using any 96+ ecu it will require that second o2 unless its a jdm ecu.
Old Jan 27, 2004 | 06:09 PM
Default Re: Quick Question Regarding (chameleon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chameleon &raquo;</TD></TR><TR><TD CLASS="quote">
if you add in a swap and use a OBD1 ecu you will not need that second o2, if you decide on using any 96+ ecu it will require that second o2 unless its a jdm ecu.</TD></TR></TABLE>
never said anything about swap's or ecu's he was just talking aobut switching exhaust setups.
you could setup an O2 simulator or something like that but just do it right
4thgenhtch
Mar 3, 2007 09:39 PM
iKhmaiFoSho
Jan 6, 2006 08:45 PM
ThefirstPACT
Sep 26, 2005 11:37 PM
TheNasty0ne
10
Jul 7, 2005 02:50 PM
ATS*Mark
16
Apr 7, 2004 08:25 AM
