Motor mount insert questions
Old Oct 3, 2001 | 04:25 PM
GraphiteAccord's Avatar
Default Motor mount insert questions
Since there are more smart people around here, check this out for me. i think my car and a prelude shair the same motor mounts. who makes sets for the prelude?
http://www.hondasociety.com/board/sh...251#post225251
reply to this thread here, thank you.
Old Oct 3, 2001 | 05:28 PM
Honda318dx's Avatar
Default Re: Motor mount insert questions (GraphiteAccord)
I got mine from energy suspension, about 35$.. They help put power to the ground sooner, but they shake the **** out of the car! Very annoying for street use..
Old Oct 3, 2001 | 10:20 PM
Default Re: Motor mount insert questions (Honda318dx)
Can you possibly give me a part number or some sort? also, is yours a set of two, or three, or all of them?
Old Oct 4, 2001 | 04:09 AM
Honda318dx's Avatar
Its just a set for the front and rear mounts, sorry, i don't know the part numbers..
Old Oct 4, 2001 | 04:28 AM
Gabe's Avatar
Why don't you just look the part numbers up yourself. ES does have a website and they do list their part numbers on it.
BTW are you only looking for an insert to stiffen up the mounts? Cause if you have a torn mount then it needs replaced before you install the inserts.
Gabe
Old Oct 4, 2001 | 06:36 AM
Honda318dx's Avatar
Default Re: Motor mount insert questions (Gabe)
I had a torn mount when I put mine in.. I should have replaced it, but i didn't have the money so I just used the inserts to "tighten" the mount up.. With the inserts in, the mount cannot move, so torn or not, it really doesn't matter, as long as it isn't about to rip apart..
Old Oct 4, 2001 | 08:48 AM
Gabe's Avatar
Well i was just stating what ES says in their instructions. I don't think that it would hurt to run a torn mount with a bushing for a while, but I would eventually replace the torn mount.
Gabe
Old Oct 4, 2001 | 12:47 PM
Gabe
Coudl you have been at all helpfull and atleast given me the address? Thank you for nothing, i want my 15 seconds back from reading your worthless post.
Old Oct 4, 2001 | 06:34 PM
4doorH22's Avatar
All I've seen are motor mount inserts for Energy Suspension (I think). If Accords have the same mounts as Ludes, I don't understand why they make only one insert for Accords and 2 inserts for Preludes.
I can't explain why, but my OE mounts are doing great right now. No "rubber-banding" in the drive train. Maybe if I was an avid drag racer I'd consider them, but they seem capable for tracking.
[Modified by 4doorH22, 10:50 PM 10/4/2001]
Old Oct 5, 2001 | 04:40 AM
Gabe's Avatar
Well for all the dumbasses in the crowd who either have no common sense or can't use a search engine it's www.energysuspension.com . I'm very sorry I didn't give that to you the first time cause it seems as if you would have a hard enough time breathing on your own so you really don't need to think about what Energy Suspension's website url might be. Jackass.
Gabe
t0kyoStatus
Mar 6, 2009 11:09 PM
dreams190
Feb 11, 2006 05:28 PM
Spectrum24x
Jul 6, 2005 10:34 PM
TypeRuz
Feb 7, 2004 10:04 PM
2000si
Nov 6, 2002 01:49 PM
