Rota C10 (MF10 replica) w/ spoon calipers. What offset?
Old Jan 26, 2004 | 06:57 AM
AssPenny's Avatar
Default Rota C10 (MF10 replica) w/ spoon calipers. What offset?
Well I've always wanted a set of MF10's, however, thanks to their $500 a piece price tag, I don't think i'll ever own a set. But now, Rota has come out with the C10 in 5 lug and I'd like to pick up a set of 16"ers. My problem is they only come in +45 offset. Will this clear the calipers or will I have to run a spacer? I'm running spacers now, so its not that big of a deal, I was just wondering.
Also, what size tire should I run on these? An suggestions?
Old Jan 26, 2004 | 06:58 AM
Willard's Avatar
Default Re: Rota C10 (MF10 replica) w/ spoon calipers. What offset? (AssPenny)
sell me the calipers and buy the wheels w/o worry.
Old Jan 26, 2004 | 11:08 AM
AssPenny's Avatar
Default Re: Rota C10 (Willard)
Nobody? Damn
Old Jan 26, 2004 | 11:14 AM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">sell me the calipers and buy the wheels w/o worry. </TD></TR></TABLE>
Make me a reasonable offer.
Though, I think I'll still probably keep mine.
Sorry Craig, no idea if the C10's will fit with the Smurf calipers, though I could try and measure my SSR wheel .... Ed
Old Jan 26, 2004 | 11:16 AM
AssPenny's Avatar
Default Re: Rota C10 (zygspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">Sorry Craig, no idea if the C10's will fit with the Smurf calipers, though I could try and measure my SSR wheel .... Ed</TD></TR></TABLE>
Thanks Ed, but I don't think it will help much. I need someone with MF10's and spoon calipers. If I remember correctly 50mm offset where the only ones that would fit. But considering the rotas only come the 45mm, guess it really doesn't matter
But what about tire size?
Old Jan 26, 2004 | 11:20 AM
Cosworth's Avatar
Default Re: Rota C10 (AssPenny)
MF10's in +50mm wiill not clear spoon calipers. But, +43mm, IIRC, MF10 clears w/o a spacer.
Would +45mm C10 clear spoonies? I dunno. Probably cutting it close and you won't know until you try it out.
Old Jan 26, 2004 | 11:24 AM
AssPenny's Avatar
Default Re: Rota C10 (Cosworth)
Well, I'm already runnning 5mm (or 8mm I don't remember) spacers so the Mazda rims will clear. Not that big of a deal really.
Old Jan 26, 2004 | 07:59 PM
gary201147's Avatar
considering sw388s are only 45 offset and clear their own calipers, i doubt that a rota of the same offset will have much trouble.
Old Jan 26, 2004 | 08:41 PM
01CWITR's Avatar
Default Re: Rota C10 (gary201147)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gary201147 &raquo;</TD></TR><TR><TD CLASS="quote">considering sw388s are only 45 offset and clear their own calipers, i doubt that a rota of the same offset will have much trouble. </TD></TR></TABLE>
should fit without spacers..
Old Jan 27, 2004 | 05:47 AM
Bradstard's Avatar
I've already got the C10's in 16" w/ 45mm offset. I'm running 215/45/16 Azenis. Why don't you send me your Spoon calipers and I'll test them for a few months on my car with the C10's. I'll let you know if you need a spacer.
Old Jan 27, 2004 | 07:20 AM
Pondus's Avatar
Default Re: Rota C10 (Fat Bradstard)
The Spoons need 2" clearance between disc surface and the rim IIRC. I think I have seen a pic somewhere with this measurement shown.
Old Jan 27, 2004 | 07:22 AM
AssPenny's Avatar
Default Re: Rota C10 (01SpecR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01SpecR &raquo;</TD></TR><TR><TD CLASS="quote">
should fit without spacers.. </TD></TR></TABLE>
The problem is that the sw388 have different spoke designs that don't hit, but the c10's will. Just like the stock rims fit with no spacer, but the mazda rims, which have the same offset as stock, hit the calipers.
Old Jan 27, 2004 | 08:04 AM
Chris N's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssPenny &raquo;</TD></TR><TR><TD CLASS="quote">Well, I'm already runnning 5mm (or 8mm I don't remember) spacers so the Mazda rims will clear. Not that big of a deal really.</TD></TR></TABLE>
y0 craig, the mazda's you have are +50 offset.
If the Rota's you are looking at are +45, you'll probably need a 2-3mm spacer, since the +43 MF10's fit over the Spoon Calipers. Or you could just use your 5mm spacers or whatever you have....
Old Jan 27, 2004 | 08:41 AM
MattD@Stoptech's Avatar
Default Re: Rota C10 (Chris N)
I can't believe everyone is talking about offset without talking about wheel width...are they all the same width?
Old Jan 27, 2004 | 08:44 AM
Reid's Avatar
Global Moderator
Default Re: Rota C10 (El Pollo Diablo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">I can't believe everyone is talking about offset without talking about wheel width...are they all the same width?</TD></TR></TABLE>
No offense, but why would wheel width matter when discussing offset in regards to wheel to caliper clearance?
Width would matter if we were discussing backspacing however.
Old Jan 27, 2004 | 08:46 AM
Default Re: Rota C10 (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">
Width would matter if we were discussing backspacing however.</TD></TR></TABLE>
Brain fart maybe?
Mugen Mike's Avatar
Two words -- die grinder
Sorry Craig, I really have no useless info for you
Old Jan 27, 2004 | 08:53 AM
Chris N's Avatar
Brain fart maybe?
LOL!
Old Jan 27, 2004 | 09:18 AM
yellow blur's Avatar
I had to learn the hardway about MF10's and Spoon Calipers. +50's don't clear, +43's do. MF10's were 16x7.
Ed
Old Jun 14, 2005 | 01:24 PM
AssPenny's Avatar
Default Re: Rota C10 (yellow blur)
Anybody try a set of C10's w/ spoon calipers yet or do I have to be the first?
Old Jun 14, 2005 | 01:34 PM
Dave-ROR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssPenny &raquo;</TD></TR><TR><TD CLASS="quote">Anybody try a set of C10's w/ spoon calipers yet or do I have to be the first?</TD></TR></TABLE>
You already use spacers so who cares biatch? just buy them, put the spoonies on the hatch with the mazda wheels/spacers and run the Rota's on the hype-r.
Old Jun 14, 2005 | 01:39 PM
AssPenny's Avatar
Default Re: Rota C10 (Dave-ROR)
I hate you Dave.
Old Jun 14, 2005 | 01:40 PM
Dave-ROR's Avatar
lol best reply ever.
Old Jun 14, 2005 | 02:12 PM
Jowee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fat Bradstard &raquo;</TD></TR><TR><TD CLASS="quote">I've already got the C10's in 16" w/ 45mm offset. I'm running 215/45/16 Azenis. Why don't you send me your Spoon calipers and I'll test them for a few months on my car with the C10's. I'll let you know if you need a spacer. </TD></TR></TABLE>
I really thought they were Moogens.
Old Jun 14, 2005 | 02:29 PM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssPenny &raquo;</TD></TR><TR><TD CLASS="quote">I hate you Dave.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave-ROR &raquo;</TD></TR><TR><TD CLASS="quote">lol best reply ever.</TD></TR></TABLE>
LOL!
Those C10s/MF10s do look really nice though, whether on CW-FBP/NHP and even PY.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellow blur &raquo;</TD></TR><TR><TD CLASS="quote">I had to learn the hardway about MF10's and Spoon Calipers. +50's don't clear, +43's do. MF10's were 16x7. </TD></TR></TABLE>
I guess ... there we have it!
