d16z6 hesitation in low rpm range...whats the prob?
Old Jan 25, 2004 | 09:11 PM
1CiViC1's Avatar
Default d16z6 hesitation in low rpm range...whats the prob?
ok, I swap the z6 in earlier this month and has been going great thus far. My problem is that when i have the rpms in say 1-2K and give it gas, it studders then goes. Its only if i have the rpms in that range(1-2k) and give it gas, everything higher than 2k is fine.
90 std, 93 d16z6, pm6 ecu etc. all suggestions are appreciated!
Old Jan 26, 2004 | 02:14 AM
1CiViC1's Avatar
Default Re: d16z6 hesitation in low rpm range...whats the prob? (1CiViC1)
Old Jan 26, 2004 | 03:42 AM
hondafanatic1's Avatar
My D15B Vtec does the same thing and I have no idea what it is.Sometimes it does it when I turn onto a road at like 1500 rpm then I have to rev it past 2000 rpm and its fine.I have replaced everything but the fuel filter and it still does it.
If you ever figure it out I would love to know.
Old Jan 26, 2004 | 05:32 AM
Hellraver's Avatar
Its either the TPS sensor or the intake manifold gasket.
Tell us hwo it goes.
Old Jan 26, 2004 | 11:31 AM
1CiViC1's Avatar
Default Re: (Hellraver)
the intake manifold gasket is brand new oem. Ill check the tps as soon as the weather clears up...
Old Jan 26, 2004 | 09:48 PM
KOOL-AID's Avatar
check fuel filter
crazyhouse2011
74
Feb 9, 2017 05:30 PM
sohc1988
Mar 29, 2010 11:26 AM
Manny 77
Nov 27, 2009 01:21 PM
cueballsi
Mar 18, 2009 06:31 PM
