Draft:Draft:'94 Turbo H22 Hatch, Chicago-Illinois
Old Jan 25, 2004 | 07:03 PM
sol-racer's Avatar
Default '94 Turbo H22 Hatch, Milwaukee, WI *** MUST GO SALE!!! ***
1994 Hatch for sale $5,500
-OBD1 JDM H22A from JDMHondaparts.com
-Factory LSD
-Clutchnet STGIII w/ 6 puck copper sprung hub
-DriveShaftShop "Level 2" Axels (500HP)
-Accord strut forks for proper axel clearance
-T3/TO4E (.63 a/r turbine and .50 compressor) (rebuilt w/ less than 1k mi)
-Fmax manifold
-Tial 35mm Waste Gate (Closed system re-entering 3" DP 12" from turbo)
-all mandrel bent stainless steel 2.5" IC piping
-all mandrel bent stainless steel 3.0" downpipe and exhaust
-stainless flex pipe/muffler/and custom exhaust flanges
-Trust's big IC (modified inlet to remove 2.5' of IC piping)
-3mm overbore on throttlebody
-lightened factory flywheel
-Accord fuel rail for correct civic fuel flow on H22
-Hasport mounts and wire harness
-Custom "micro-bar" aluminium radiator with push/pull 12" fans
-Front and rear sway bars from Integra GSR
-Front brakes from Del Sol VTEC
-Stainless steel brake lines
-Autometer Electric Fuel Pressure, EGT, Boost, A/F, Oil Press, Monster Tach, Shift Light
-HKS Type1 Turbo Timer
-Full Prothane Poly Kit Installed (EVERY BUSHING EVERYWHERE!!!)
-Walbro 255lph High Pressure fuel pump
-MOMO hood pins (real, not for show)
-and lots of other minor stuff to make the install reliable, fast, and safe.
BAD STUFF-
-2 minor surface rust spots on back wheel wells of both rear sides (you know the spots where ALL hondas rust)
-Chassis has 186K on it. Almost every moving part or electrical part has been replaced but the chassis is still what counts I guess.
-WILL NOT PASS EMISSIONS (Don't even try it.)
I love this hobby and this car is everything I ever wanted in a honda but, I have gone as far as I care to with it. The next step is to build the motor and I just don't have the time.
I have done all the work myself and have receipts for EVERYTHING, so I you have any questions, I have answers.
(The car is on stands for now, hense the jacked up look)
If you want more pics just let me know of what...
Thanks guys and especially H-T... some great ideas came from here.
Here is a link for many more pictures....
http://www.imagestation.com/album/?id=4286958335
Modified by sol-racer at 3:54 PM 5/8/2004
Modified by sol-racer at 11:12 AM 10/17/2004
Modified by sol-racer at 11:13 AM 10/17/2004
Modified by sol-racer at 8:15 PM 11/5/2004
Old Jan 25, 2004 | 07:50 PM
CivicT's Avatar
Default Re: '94 Turbo H22 Hatch, Chicago-Illinois (sol-racer)
How low has this been dropped? TTT
Old Jan 25, 2004 | 08:34 PM
sol-racer's Avatar
They are adjustable coil-overs (striaght rate 400 lbs front and 300 lbs rear) The current drop is approxamately 2.5" I dropped it until the axels sat parallel with the ground. This is the best position for higher horsepower applications during autocrossing.
2 0 3's Avatar
Default Re: '94 Turbo H22 Hatch, Chicago-Illinois (CivicT)
BUMP This is an Awsome deal. I sold my Stock H22 93 hatch for close to his asking price...jump on this one guys
Old Jan 25, 2004 | 08:37 PM
sol-racer's Avatar
Default Re: '94 Turbo H22 Hatch, Chicago-Illinois (allmotorDA6)
Thanks, I think so too...
Old Jan 25, 2004 | 09:51 PM
sol-racer's Avatar
Default Re: (bublik)
You know the weather just as well as I do, so give me a day... sun and mon are the best. (Days off)
Old Jan 26, 2004 | 10:43 AM
sol-racer's Avatar
TTT
Old Jan 27, 2004 | 01:32 PM
CivicT's Avatar
How fast is this thing? TTT
Old Jan 27, 2004 | 07:14 PM
sol-racer's Avatar
Default Re: (CivicT)
Fast enough to to simply push the gas pedal down crusing in third and start smokin' em...
Old Jan 27, 2004 | 07:59 PM
4inspeed's Avatar
Default Re: (sol-racer)
all i can say is damn... that ish has got to be fast.
Old Jan 27, 2004 | 08:23 PM
aktc167's Avatar
better find another z06 and burn them for revenge!
Old Jan 27, 2004 | 09:10 PM
Default Re: (aktc167)
TTT for a Torque Monster
Old Jan 28, 2004 | 06:57 PM
sol-racer's Avatar
It's really hard to sell this car with 8" of snow on the ground... but I'll still try. Anyone seriously interested???
Old Jan 29, 2004 | 06:01 PM
sol-racer's Avatar
TTT for 2 degress above zero and -30 windchill and I'm trying to sell a summer car...
Old Jan 29, 2004 | 08:57 PM
aktc167's Avatar
i just noticed that phat custom intake for the turbo lol. pretty neat.
Old Feb 1, 2004 | 07:35 AM
sol-racer's Avatar
Default Re: '94 Turbo H22 Hatch, Chicago-Illinois (aktc167)
It was the only way to keep a 3" intake and not have to move the radiator. Besides, the turbo only had a 2.5" inlet so I used 3" to 2.5" cone (velocity stack) to get what I wanted...
Old Feb 2, 2004 | 12:33 PM
sol-racer's Avatar
TTT for ordering a bigger turbo for it today... Should give me better top end pull, know what I'm sayin'?
Old Feb 2, 2004 | 02:21 PM
Loaded Butane's Avatar
Sweet ride. I bet its fun to drive.
Old Feb 2, 2004 | 05:08 PM
sol-racer's Avatar
Default Re: '94 Turbo H22 Hatch, Chicago-Illinois (Loaded Butane)
Yeah it really is... I wonder sometimes why I am selling it.
Old Feb 2, 2004 | 06:59 PM
hybrid515's Avatar
kool
Old Feb 2, 2004 | 11:54 PM
Pojazz's Avatar
Default Re: '94 Turbo H22 Hatch, Chicago-Illinois (hybrid515)
I've seen this car guys. It's straight up solid. Someone is getting a kick *** car.
Steve
Old Feb 3, 2004 | 07:24 PM
sol-racer's Avatar
Default Re: '94 Turbo H22 Hatch, Chicago-Illinois (Pojazz)
DUDE!!! What's up man? Are you still a NISMO guy? How much of my bro's turbo kit did you buy and are you done installing it?
By the by... thanks for the props on the car... when the snow goes away I owe you a ride.
Old Feb 7, 2004 | 01:16 PM
b16hybridsol's Avatar
hey bump for your hatch, and a question, where did you get that radiator because i need the exact same thing, my t3/60-1 doesn't like my stock teg radiator at all ha
Old Feb 7, 2004 | 01:42 PM
Jinya1004's Avatar
Default Re: '94 Turbo H22 Hatch, Chicago-Illinois (b16hybridsol)
Bizump for the seller. Bump for hating snow and waiting for nice weather so we can go cruising!
Old Feb 8, 2004 | 02:09 PM
integra_si-vtec's Avatar
cool dood
