NO HEAT HELP I'M FREEZZZZZINGGGGGGGG
Old Jan 25, 2004 | 05:18 PM
scdarksol's Avatar
Default NO HEAT HELP I'M FREEZZZZZINGGGGGGGG
Hey guys I have a 91 4dr lx, and I'm getting No HEAT. I get a tiny little little heat in position 1 when I put it to 2 3 and 4 it blows COLD air. I changed thermostat, upper rad hose, rad cap, and the heater control valve cable moves. I also checked if the hose behind the heater control valve gets hot or not. And it does, I also checked inside the blower motor and it's not clogged or anything. ANYBODY have any idea? I'M FREEEZZZZZINNGGG thank you!
Old Jan 25, 2004 | 08:24 PM
vitrox's Avatar
replace your radiator cap also. hopefully thats your problem. Otherwise make sure the valve inside the engine bay is moving freely when you adjust your cold/hot dial. The valve is next to the firewall, you will see it.
thewrai6th
Mar 10, 2016 04:24 PM
Teggy_DC2
Feb 11, 2016 12:29 AM
Shaw14
Dec 21, 2009 12:30 PM
88CRXJ
Oct 12, 2009 08:01 PM
fallmartin
Dec 2, 2008 05:01 PM
