What does the Beaks or BSQ kit look like and whats the difference?
Old Oct 3, 2001 | 12:51 PM
BlueG3Teg's Avatar
New User
Default What does the Beaks or BSQ kit look like and whats the difference?
This may be a stupid question but I've been considering getting an ITR swaybar for my car.
I know I need the reinforcement kit but whats the difference between the Beaks kit and the BSQ kit?
Anyone got pics of what they look like?
Thanks
Old Oct 3, 2001 | 01:20 PM
Mario's Avatar
Default Re: What does the Beaks or BSQ kit look like and whats the difference? (BlueG3Teg)
Beaks is more expensive and prettier than the BSQ kit. BSQ gets the job done though.
Old Oct 3, 2001 | 01:47 PM
H23 Power's Avatar
Default Re: What does the Beaks or BSQ kit look like and whats the difference? (Supersonic DC2)
http://www.geocities.com/bretq/swaybar_install.html
Old Oct 3, 2001 | 06:50 PM
Chairman Kaga's Avatar
Default Re: What does the Beaks or BSQ kit look like and whats the difference? (01GSR)
BSQ looks good, and I like the idea of buying something someone on the boar sells.
I've looked for the Beak's, and I can't find it anywhere. Just install instructions.Any clues where I can find it?
Old Oct 3, 2001 | 10:03 PM
Isaac's Avatar
New User
Default Re: What does the Beaks or BSQ kit look like and whats the difference? (chairmankaga)
I have the Beaks kit which I used w/ my ITR Swaybar. The Beaks kit reinforces the inside and outside of the subframe for even more protection than the BSQ kit. Bret is a very intelligent/informative guy and he seems to have had no problems w/ his car and his method is very inexpensive. I bought the Beaks kit just for the extra protection, because what is another $20-30 considering the cost to fix subframe tearout. Good Luck either way.
Old Oct 3, 2001 | 10:17 PM
Abez's Avatar
Default Re: What does the Beaks or BSQ kit look like and whats the difference? (98 GS-R)
Try this e-mail: BeaksProducts@hotmail.com. I installed the Beaks kit and have no problems. Beaks kit cost me $60 from tegsportracing.com. The site looks like it has changed so try the e-mail address for info.
Old Oct 4, 2001 | 11:40 AM
RineRacing's Avatar
BSQ Kit
14 AutoX events and counting. No signs of tear-out.
Also I believe BSQ uses a steel plate and Beaks uses aluminum.
[Modified by Geratol, 12:40 PM 10/4/2001]
Old Oct 4, 2001 | 03:52 PM
Nighthawk GS-R's Avatar
New User
Default Re: What does the Beaks or BSQ kit look like and whats the difference? (Geratol)
so whats the concensus? which kit is everyone recommending?
Old Oct 4, 2001 | 04:29 PM
2kbill's Avatar
Default Re: What does the Beaks or BSQ kit look like and whats the difference? (Nighthawk GS-R)
Beaks kit. There is a matching threaded plate on the other side.
Old Oct 4, 2001 | 04:35 PM
RacingE_Teg's Avatar
Default Re: What does the Beaks or BSQ kit look like and whats the difference? (2kbill)
I've got the Beaks kit
Old Oct 4, 2001 | 06:12 PM
Erik95LS's Avatar
Default Re: What does the Beaks or BSQ kit look like and whats the difference? (RacingE_Teg)
i hope another big argument doesn't ensue, but you really can't go wrong with either kit. it's more of a preferance situation. some (like me) feel that the BSQ kit more than gets the job done. Others feel that the added surface area provided by the Beaks kit is worth the extra money. it's up to your own tastes really.
Old Oct 4, 2001 | 08:52 PM
blaze's Avatar
the threaded plate does make it easier to install... not that the BSQ kit is hard to install. just makes it easier.
beaks is what i have and still no problems
Old Oct 4, 2001 | 09:49 PM
crookedletterd's Avatar
New User
Default Re: What does the Beaks or BSQ kit look like and whats the difference? (blaze)
what are we looking at
Old Oct 4, 2001 | 10:07 PM
BlueG3Teg's Avatar
New User
Geratol and 2kbill: Thanks for the posting up the pictures. It is very helpful to see the difference between the two reinforcement kits.
However, the Beaks kit does look like there is alittle more support.
Where can I purchase the Beaks kit and whats the price for the Beaks kit and BSQ kit?
Old Oct 4, 2001 | 10:22 PM
Rain_man's Avatar
New User
The Beaks kit was 60 and the BSQ kit 20.
You should look over the install directions for the beaks kit vs. the BSQ kit. Last time I recalled, the BSQ kit was easier to install.
Old Oct 5, 2001 | 01:30 AM
2kbill's Avatar
Default Re: What does the Beaks or BSQ kit look like and whats the difference? (Ein)
You can try BeaksProducts@hotmail.com - that worked in December 2000.
Bill
Old Oct 5, 2001 | 09:21 AM
New User
im really ******* stupid right now, someone point out the difference? or better yet what the hell are we looking at?
Old Oct 5, 2001 | 11:14 AM
BSQ's Avatar
BSQ
Here is a diagram which may clarify where the mounting kit is located and why it is needed. You can see that the mounting surface on the suspension subframe is not flat on non-Type-R Integras. Therefore, you will need a mounting kit to allow the Type-R rear swaybar to be properly mounted to the subframe. The mounting kit also reinforces the subframe sheetmetal, which prevents subframe tearouts. HTH
. o 69 o .
Jan 8, 2003 05:43 PM
grngsr01
Oct 3, 2002 11:22 AM
ste_smith
Apr 11, 2002 04:25 PM
ndustryalGSR
Dec 15, 2001 02:46 PM
