2001 F23A compression check? how to?
Old Jan 25, 2004 | 02:53 PM
Swift_asian's Avatar
Default 2001 F23A compression check? how to?
friend mis 4 and hit 2nd instead.... i want to do a compression check.
-can someone tell me the comp. ratio on a F23A thanks
-and the procedure pls
Old Jan 25, 2004 | 04:25 PM
Crono139's Avatar
Default Re: 2001 F23A compression check? how to? (Swift_asian)
As long as all 4 cylinders read the same (or very close) number, it's fine.
Examples.
180 180 180 180 = Smooth sailing.
180 180 180 155 = Houston, we have a problem.
You can buy a tester at your local Pep Boys, or AutoZone. Around $30.
Old Jan 25, 2004 | 05:24 PM
iam7head's Avatar
Default Re: 2001 F23A compression check? how to? (Crono139)
10 percent or more different between cylinder=engine going south
autozone rent them out for free i think
Old Jan 25, 2004 | 05:53 PM
Crono139's Avatar
Default Re: 2001 F23A compression check? how to? (iam7head)
You can rent them? Since when?
Old Jan 25, 2004 | 06:58 PM
thanx for the replys...
did compression check results
4 (230) 3 (210) 2 (210) 1 (215)
# came out pretty good... i told my friend to memorize wich lines to match on the distributor and he didnt .... first attempt to start the car( sounds like a freaken CAMMED 5.0).... after 5-6 times of trying and error finaly go the car started....
Old Jan 25, 2004 | 07:10 PM
Crono139's Avatar
Aren't the stock wires numbered?
I'm pretty sure they are.
Old Jan 25, 2004 | 09:59 PM
lol plug wires are # but distributor are not lol.... he put back his stock PLug wirez.... cuz he broke the OBX ones hahah OBX wut can i say.......
Old Jan 26, 2004 | 06:00 AM
97F22B2's Avatar
Isnt that compression a little high for the F23A? IF its anything like my F22 it should be around 180.
Old Jan 26, 2004 | 10:00 AM
jweller's Avatar
Default Re: (97F22B2)
f23 has higher compression than f22
the numbers are also related to the number of times you crank it
Old Jan 27, 2004 | 09:31 PM
accord20o1's Avatar
Default Re: (jweller)
isnt it the same? i think the F23 accords are 9.3:1 right?
Old Jan 28, 2004 | 09:09 AM
jweller's Avatar
Default Re: (accord20o1)
f23 vtec motors are 9.3:1
I'm pretty sure f22 motors were in the high 8s:1
GoldCoin
Aug 23, 2006 07:02 PM
Pandahatch
Aug 31, 2004 11:59 PM
Ochux
Nov 8, 2001 12:52 PM
