rpm jumping at 1500 to 2000 rpm
Old Jan 25, 2004 | 11:12 AM
H22CL's Avatar
Default rpm jumping at 1500 to 2000 rpm
I have a jdm h22 into my CL. Heres the deal, my car idles very smoothly (can barely tell it's on), but precisely between 1500 and 2000 rpm it surges up and down. I'll sit in the car will it's in nuetral and rev it slowly and when it gets to 1500 it'll start the jumping up until 2000 rpm, after that it's smooth again, do you have any idea as to what the hell is causing this? Thanks, Leon!
Old Jan 25, 2004 | 11:25 AM
H23vtecEG's Avatar
Default Re: rpm jumping at 1500 to 2000 rpm (H22CL)
idle control valve. check the two hoeses that come out of it and replace them with new ones. mine usually does it when i have my distributor advanced all the way
Old Jan 25, 2004 | 11:28 AM
H22CL's Avatar
advance could be the problem, I remember when my swap was done my mechanic was twisting my dizzy back and forth. turning it to the front of the car is advance right and turning it to the firewall is retard? correct me if i'm wrong!
tmont2
Feb 5, 2009 03:02 PM
hones
Aug 2, 2004 12:44 PM
H22CL
Jan 25, 2004 12:22 PM
MugenizedR
Oct 29, 2003 08:27 PM
