matching amp to sub
Im pretty much audio illiterate so id like some recommendations from you guys on to what amp i should run. The sub is an infinity kappa 10" in sealed box. Its an older Kappa series (the green-ish blue). I got for a great price.
Ive heard compared to the current line, the older infinity's hit harder. Has anyone had any experience with them?
I havent purchased an amp yet but im trying to narrow it down to a few choices. Feel free to suggest other ones in about the same price range as well.
PIONEER GMX922
http://cgi.ebay.com/ws/eBayISA...39736
Pioneer GM-X632
Alpine MRP M350
http://www.crutchfield.com/cgi...avf=N
Ideally id like to stay with the pioneer amps to match my headunit, but that probably doesnt matter does it.
The PIONEER GMX922 is 300watts RMS, while my sub is 275rms, Ive heard the pioneers are also overrated a bit.
The pioneer GM-X632 is 150watts RMS, Will this be sufficient to push the sub at a decent level?
In the end, Im looking for clear, tight bass to complement my highs.
Thanks.
edit: one more amp, is this too much?
Pioneer GM-X972
http://www.pioneerelectronics....onent
Modified by m0neynh0s at 11:29 AM 1/27/2004
PIONEER GMX922
Pioneer GM-X632
Alpine MRP M350
Thanks.
Pioneer GM-X972
you can't choose an amp without knowing what the coil config is on the amp...
If you have a multimeter, you can measure the impedance of your subwoofer. If you don't have that, or if youhave no clue what I'm talking about, get us a model number
oh yea, a model # might help.
Infinity Kappa Series
100.1se
Impedance: 4 Ohms
Power Handling Peak: 800W
Power Handling RMS: 200W
Sensitivity: 93dB
Frequency Response (± 3dB): 25Hz - 250Hz
Fs (Hz): 31.91
Qts: 0.41
Vas (liters): 50
Xmax (mm): 7.43
Levc@1kHz (mH): 2.43
Modified by m0neynh0s at 11:30 AM 1/27/2004
100.1se
Impedance: 4 Ohms
Sensitivity: 93dB
Fs (Hz): 31.91
Qts: 0.41
Vas (liters): 50
Xmax (mm): 7.43
chunty kevin
Mar 11, 2008 01:22 PM
SD1222
Audio / Security / Video
Oct 18, 2004 08:42 PM
