Spark plugs: running lean or just too old?
Old Jan 25, 2004 | 06:56 AM
theBird's Avatar
Default Spark plugs: running lean or just too old?
My engine is stock with 145,xxx miles with a AEM short ram intake and custom cat back exhaust. Is this a sign that my A/F mix is lean? Or would it be better to show the new plugs after a few thousand miles?
btw, this is my first time changing them since i bought the car a few months ago.
Modified by theBird at 11:31 AM 1/25/2004
Old Jan 25, 2004 | 10:17 AM
mmuller's Avatar
Mad Scientist
Default Re: Spark plugs: running lean or just too old? (theBird)
they look ok to me, but put new ones in and go drive.come back and check the color.
Old Jan 25, 2004 | 10:28 AM
Kataku2K3's Avatar
Default Re: Spark plugs: running lean or just too old? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">they look ok to me</TD></TR></TABLE>
That's what I say... Swap some new plugs in and read them again... Color wise your fine but you'll be the one who can see detonation (any pits in the electrode or porcelain) as we can't really tell from the pics...
Old Jan 25, 2004 | 10:38 AM
hondatim's Avatar
Default Re: Spark plugs: running lean or just too old? (Kataku2K3)
Detonation causes little silvery white specs (think teeny tiny metal) on plugs. Generally way inside the plug below porcelain. Probably won't be able to see detonation with bare eye. Generally use magnifying glass.
As for your plug condition, looks OK.
But I would suggest getting rid of those Bosch Platinum +4's and switching back to non-platinum plugs, like NGK or Denso.
By experience ,for some reason, Bosch plugs especially don't seem to perform well in Honda engines. ]
Again, this is based on my experience. Others may disagree with me.
Old Jan 25, 2004 | 10:49 AM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default Re: Spark plugs: running lean or just too old? (hondatim)
plus those plugs suck *** get some different ones any way bosch +4 are not good
Old Jan 25, 2004 | 11:24 AM
theBird's Avatar
Thanks for the replies!
I thought they were in bad condition, but what is detination exactly?
I found a new pack of platiums by the spare tire so I replaced the old ones... except the plats that I'm using now are a single electrode.
Old Jan 25, 2004 | 11:32 AM
Kamin's Avatar
those look ok to you guys!??! holy ****!
the electrode should be CARMEL colored, not WHITE
get denso or NGK plugs, no need for that 4 tipped bullshit.
Old Jan 25, 2004 | 11:44 AM
B18C2_sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatim &raquo;</TD></TR><TR><TD CLASS="quote">Detonation causes little silvery white specs (think teeny tiny metal) on plugs. Generally way inside the plug below porcelain. Probably won't be able to see detonation with bare eye. Generally use magnifying glass.
Again, this is based on my experience. Others may disagree with me.</TD></TR></TABLE>
change plugs and feel the NGK power. OEM all the way
Old Jan 25, 2004 | 12:24 PM
hondatim's Avatar
Default Re: Spark plugs: running lean or just too old? (Kamin)
Kamin,
It's not uncommon for the color of these type of plugs to be that color of white. Yes carmel is what you want plugs to look like, however,these plugs for some reason tend to always look this way after use. It also depends on fuel quality and type as well.
Yes, those plugs do look a little lean, I mean a little, but wouldn't be anything that I would jump the gun on and point a finger at until after I installed better plugs and drove and then rechecked.
1.8L_allmotormilitia
Sep 13, 2007 11:43 AM
uLTrAvTEc757
Honda Civic (2006 - 2015)
Sep 5, 2006 05:27 PM
numotive
Aug 4, 2005 11:26 AM
itr1244
Apr 26, 2004 03:24 PM
zseeanz
Dec 2, 2003 07:25 AM
