are your wiper arms loose????
Old Jan 24, 2004 | 06:14 PM
EFSiR's Avatar
Default are your wiper arms loose????
with the wipers all the way down on the windshield, I can manually move them up about 2"! I'm pretty sure that other cars don't do that but with my EF going fast, the wind moves them up about 2" up. Sooo anoying.
How do I fix this?
I did check the wiper motor and it seems to be ok.
TIA
Old Jan 24, 2004 | 06:54 PM
xci_ed6's Avatar
Default Re: are your wiper arms loose???? (EFSiR)
take off the cowl, pull out the linkage, and check the bushings.
Old Jan 24, 2004 | 07:08 PM
T-Mo's Avatar
mines do the same thing and it IS veri annoying
Brett420's Avatar
did you check to see if the arms are worn or loose? The armhave little grooves in them that line up to ridges on the studs.
Old Jan 24, 2004 | 07:18 PM
EFSiR's Avatar
Default Re: (Brett420)
never thought that this could get busted...
Old Jan 24, 2004 | 07:37 PM
slowman's Avatar
I took way too long
Default Re: (EFSiR)
No mine are not loose. i'm glad they are not that would be very annoying.
Old Jan 24, 2004 | 11:29 PM
4crx4me's Avatar
Default Re: are your wiper arms loose???? (krustindumm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krustindumm &raquo;</TD></TR><TR><TD CLASS="quote">take off the cowl, pull out the linkage, and check the bushings.</TD></TR></TABLE>
Yes, if they move that much it means the bushings on the linkage arms are shot.
And the arms need to be replaced. I've done this a couple of times on 2g tegs it's not that bad. But it is a PITA. You have to replace the whole arms, you can't just replace the bushings, because honda doesn't sell them seperately.
dozer95
Jul 18, 2017 05:18 PM
melanie926
Honda CR-V & Element
Jan 13, 2014 06:00 AM
dakota1820
Honda Civic (2001 - 2005)
23
Mar 18, 2013 09:33 PM
tekniq
10
Aug 24, 2008 11:41 PM
Swolers
Apr 9, 2005 07:24 PM
