What are the Torque specs for the head bolts...
step 1 22ft/lbs
step 2 49ft/lbs
so bascialy set the torque wrench to 22, tighten them all at 22, then set it to 49 and retighten then to 49
step 2 49ft/lbs
You don't even need a torque wrench for that. I'm thinking we didn't tighten them down enough but that seems awfully low. I was figuring around 200 ft lbs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JonGP4 »</TD></TR><TR><TD CLASS="quote">over tighting and under tighting are great ways to warp ur head fast
And if you torque all down the entire torque spec, it'll warp the head too.......you gotta do it in thirds (well, thirds for maybe machining stuff)....or at least in half to avoid warping.
</TD></TR></TABLE>And if you torque all down the entire torque spec, it'll warp the head too.......you gotta do it in thirds (well, thirds for maybe machining stuff)....or at least in half to avoid warping.
4door93civic
Jul 23, 2006 08:43 PM
