BSQ kit??
Old Oct 3, 2001 | 07:51 AM
Nighthawk GS-R's Avatar
New User
Default BSQ kit??
i just purchased an ITR rear sway bar and was wondering if i needed the bsq kit, being i have itr rear LCA's? could someone explain to me why i woul need this kit?? sorry for stupid question, just a bit confused
Old Oct 3, 2001 | 08:09 AM
Mario's Avatar
Default Re: BSQ kit?? (Nighthawk GS-R)
Yes, a reinforcement kit (bsq or others) is highly recommended to prevent tear outs. The ITR rear lca will not affect the chances of this common problem occuring in Non ITR w/ ITR rear swaybar.
Basically, you are bolting down a larger diameter (stiffer) swaybar on a car not designed to handle the extra tension. Therefore, the bsq kit almost absolutely necessary.
[Modified by Supersonic DC2, 9:19 AM 10/3/2001]
Old Oct 3, 2001 | 08:10 AM
mercury's Avatar
New User
See where your stock swaybar mounts to the body? Without the BSQ kit or some other reinforcement method, the ITR bar will rip those mounting points right off the frame.
Old Oct 3, 2001 | 10:50 AM
newspeedR's Avatar
yes, you will need the bsq kit... if you are looking for it, i have 1 set that i never used... drop me a line...
slateEKsi
Jun 7, 2015 10:20 AM
oMek
May 14, 2004 05:40 PM
fstgsr
May 22, 2003 10:04 AM
Guam_CiviC619
Sep 16, 2002 05:24 PM
ESCALVANTE
10
Dec 28, 2001 11:48 AM
