1989 crx hf idle surge with stock motor but defroster will stop surge for 3 -4 mins? Help!!!
Old Jan 24, 2004 | 08:13 AM
deftones0817's Avatar
Default 1989 crx hf idle surge with stock motor but defroster will stop surge for 3 -4 mins? Help!!!
K I bought this car like last month and I havent got it though inspection yet. I need to before I put my b18c1 in so please help me out. The car will surge between 1000 - 1500 rpms at idle and when i get on the gas it is fine. If I turn on the rear defroster the car will start to idle normal for about 3 - 4 minutes then the surge will begin again. What should I check first? I need to get this fixed quick as possible.
DEF
ps also what front spindles do i need to put the b18c1 into a crx...i dont know what kind to look for?
Old Jan 24, 2004 | 11:36 AM
Newt Dog's Avatar
Default Re: 1989 crx hf idle surge with stock motor but defroster will stop surge for 3 -4 mins? Help!!! (d
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deftones0817 &raquo;</TD></TR><TR><TD CLASS="quote">K I bought this car like last month and I havent got it though inspection yet. I need to before I put my b18c1 in so please help me out. The car will surge between 1000 - 1500 rpms at idle and when i get on the gas it is fine. If I turn on the rear defroster the car will start to idle normal for about 3 - 4 minutes then the surge will begin again. What should I check first? I need to get this fixed quick as possible.
DEF
ps also what front spindles do i need to put the b18c1 into a crx...i dont know what kind to look for?</TD></TR></TABLE>
Check IACV valve
Check to see if throttlebody is gumed up
Check antifreeze..
chompy630
Mar 9, 2006 05:04 AM
Junkyard2000
Sep 14, 2005 07:07 PM
b20izzle
Jan 10, 2005 10:10 AM
jspec rsx
15
Jan 11, 2004 08:10 AM
