upper spring perch installed wrong?
Old Jan 24, 2004 | 07:11 AM
suspendedHatch's Avatar
Default upper spring perch installed wrong?
Is it possible to install the upper spring perch incorrectly? Would this cause a great deal of negative caster?
I recently did a coilover install and a LS brake/GSR swaybar swap on my 93 Civic HB. I didn't notice the huge amount of negative caster on the front driver's side wheel until the car was lowered. The other three corners look fine.
Old Jan 25, 2004 | 09:24 AM
Default Re: upper spring perch installed wrong? (shaundrake)
No one knows?
Old Jan 25, 2004 | 12:47 PM
func-tion's Avatar
are you refering to camber?
If the ride height is equal all of the way around you my have a worn bushing, bent controll arm, worn ball joint, or something is really fubar and not installed correctly.
Probably a good way to diagnose the problem would be to take your car and get it aligned at a shop that has a lifetime gaurentee, or atleast a gaurentee that good for a few months and they may be able to pinpoint whats wrong.
After they tell you either have them fix it or you could do it yourself and have them do the alignment again.
Old Jan 26, 2004 | 11:16 AM
Default Re: upper spring perch installed wrong? (func-tion)
Thanks for the reply. I didn't think I would get one.
No, definately caster, not camber.
No alignment shop will touch a car with coilovers. I can't take it to a shop cuz they are all completely shady, especially alignment shops. They charge you all this extra money cuz you're "custom", fix the wrong thing, and do poor work.
It's gotta be a bushing like you said.
sportyaccordy
Suspension & Brakes
Apr 17, 2006 01:01 PM
Jeff99Base
Aug 7, 2004 08:19 PM
Renegade
Dec 16, 2003 06:03 PM
Project99EK
Nov 15, 2003 08:57 AM
blanktape
May 21, 2003 10:07 PM
