CEL #7
Old Jan 24, 2004 | 01:12 AM
aVstAr's Avatar
Default CEL #7
I need your help, I'm running a spoon chipped obd-0 pr3 and I'm throwing CEL 7. Can someone please tell me what this code is? It only comes on after I warm the car up and hit vtec(arounnd 60mph)I'm thiking it's just the knock sensor. Thanks!
Old Jan 24, 2004 | 10:49 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: CEL #7 (avscrx)
Code#7 is throttle angle
There is a downloadable manual with VTEC supplement
located @ http://www.icelord.net/honda/repair/
Old Jan 24, 2004 | 10:51 AM
RCautoworks's Avatar
Default Re: CEL #7 (88DXCRX)
Code 7 - Throttle Position/Angle Sensor
TPS sensor input is used to determine when the throttle is:
Idle
Wide Open Throttle (WOT)
Rapid Movement
During these conditions the ECU makes changes to the injector Pulse Width (PW).
The PW is widen slightly when the throttle initially goes to idle. Within a few seconds the O2 sensor will correct the mixture.
Closed Throttle Input (under .5V), engine RPM is above 1100, engine is warm. The fuel injectors will be shut-off (used to conserve fuel). Peeps with A/F Ratio Meters will see this happen, when the gauge drops to full lean, or no reading at all.
When Wide Open Throttle is detected the PW is increased above normal fuel delivery. This is also known as "Open Loop" operation, when the ECU ignores the output from the O2 sensor.
With Rapid Throttle Opening the ECU is watching the TPS input voltage for rapid changes. A sudden rise in the voltage would mean the throttle was opened quickly. So the ECU would increase the PW momentarily. As soon as the MAP sensor senses the drop in vacuum, it will take over.
Testing - With the Key On, Engine Off hook up a voltmeter to the TPS. @ idle (closed throttle), voltage should be close to .5V and @ WOT (Wide Open Throttle) voltage should be 4.5V.
The best way to adjust the TPS voltage is @ idle (closed throttle). While Key On, Engine Off, hook up voltmeter between the yel/wht & grn/wht and observe reading. If it needs to be adjusted, loosen the TPS mounting and move the TPS until voltmeter reads close to .5V. The check engine light will let you know immediately whether you missed up or not.
TPS Sensor Wires:
1 Red/Blue
1 Green/White
1 Yellow/White
Old Jan 24, 2004 | 03:59 PM
aVstAr's Avatar
Default Re: CEL #7 (90blackcrx)
Thanks guys!! One more thing, does this hamper the performance of the engine?
Old Jan 24, 2004 | 09:08 PM
aVstAr's Avatar
bump
Old Jan 26, 2004 | 02:00 PM
aVstAr's Avatar
The CEL comes on when I shift hard from 2nd gear into 3rd. Then, everytime I shut off the car and start it back up the CEL is gone.
EkLanta
Nov 5, 2007 04:38 AM
hybrider
Apr 18, 2007 04:15 PM
hondaokie
Jan 14, 2005 01:28 PM
CrX-To-Tha-Max-v2.0
Nov 20, 2004 03:05 PM
SuzukaBlueAP2
Oct 16, 2003 02:39 PM
