B18 Interchangeable Replacement parts?
Hello All,
Just purchased a B18a out of a 91 teg ls. It is missing the alternator, distributor, fuel rail, and the exhaust manifold.
I was wondering if anyone knows what parts are are interchangable, for instance, can a distributor from a 94 gsr work on this engine?
Or less detailed, for instance, will parts from a b18c work on a b18a. What years are interchangeable, for instance are b18's from 91 the same as in 97?
Are any of the parts interchangable with 88-89 tegs, like the distributor?
Thanks for any help you can offer!
-John
-John
Your questions are all over the board but I'll try and address what I've been learning lately.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquariust »</TD></TR><TR><TD CLASS="quote">What years are interchangeable, for instance are b18's from 91 the same as in 97?</TD></TR></TABLE>
B18s up to 93 are OBD0. B18s from 94-95 are OBDI. B18s from 96 up are OBDII.
Here's an article on what OBD means. http://pgmfi.org/resources/FAQ/#whatisobd
The differences in years (OBD differences) create wiring problems when swapping parts. For example...a 1994 LS ECU is OBD1 and will work with a 1991 LS engine however, you need a whole lot of other parts to make it work (OBD0-OBD1 wiring harness, OBD1 distributor, etc.)
I'm still learning all this too. Hope I was somewhat helpful.
Ben
Ben
s520player
Jun 20, 2003 01:36 PM
