JDM ITR throttle body
62mm is the inside diameter , thats the reason you are getting different answers because some peeps are measuring the out side . An after market is 66-68mm like bbk , ERE, and many more . Spoon TB which starts at 70 but the inside 64mm since it has been ported ...
....and the i/m is 64mm. That is supposely why the intake whistles. (b/c they are not port matched)
GSR t/b 60mm.......i/m 62mm
All ITR t/b 62mm........i/m 64mm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScorpioX »</TD></TR><TR><TD CLASS="quote">is it possible that my jdm throttle body is 66m on the outside and 64mm on the inside?
If someone ported it, yes. But as mentioned before, all ITR TB's taper from 66mm to 62mm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOLDBERG »</TD></TR><TR><TD CLASS="quote">so if the itr tb is 62mm...what size is the skunk2 manifold opening??62?i thought it was 64?</TD></TR></TABLE>
Skunk2 IM opening is 65mm if I remember correctly.
62 mm at the butterflly, for both USDM and JDM ITR throttle bodies.
I can make it 65mm at the butterlfy and 70 at the opening with a tapered and polished inside.
Click on the link on my signature for info about boring throttle bodies.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed »</TD></TR><TR><TD CLASS="quote">Always thought it was 62 mm for an ITR (both JDM and USDM/CDM).</TD></TR></TABLE>
