5th gen DIY fogs???
Old Jan 23, 2004 | 12:24 PM
fw190bvi's Avatar
Default 5th gen DIY fogs???
Ok, ive heard of a few people doing this, and i was wondering how much work it entails besides spicing wires......swaping the front bumper blinkers w/ the corners....as in, making the corners act as a blinker, and then putting in higher output bulbs in the bumper as a driving/fog light.....anyone ever heard of it.....???
Old Jan 23, 2004 | 12:34 PM
The_Todd's Avatar
Farts in the shower
Default Re: 5th gen DIY fogs??? (fw190bvi)
Here is a write up for a 4th gen, should be the same: http://www.cb7tuner.com/vbb/sh...=1917 and it includes if you want a functional bumper light or a solid one too...hope it helps.
Edit: Also if you scroll down to the bottom it explains for 5th gens and the use of a dual filament bulb. And I know a lot of people use 92-95 civic corner housing due to its a dual filament housing which will prevent melting.
Modified by VRDrvr at 2:48 PM 1/23/2004
Old Jan 23, 2004 | 12:45 PM
cd5_2NR's Avatar
Default Re: 5th gen DIY fogs??? (VRDrvr)
i did that to my 4th gen...be careful..most of the time the bulbs get too hot and they melt the inner housing of the signal light...it does look tight though..but from my experiences the housing melted inside....
Old Jan 23, 2004 | 03:07 PM
spankey167's Avatar
Default Re: 5th gen DIY fogs??? (zeROTWO_CG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeROTWO_CG6 &raquo;</TD></TR><TR><TD CLASS="quote">i did that to my 4th gen...be careful..most of the time the bulbs get too hot and they melt the inner housing of the signal light...it does look tight though..but from my experiences the housing melted inside....</TD></TR></TABLE>
I've got that done on my 4th gen and noticed that the housing gets melted, but that was when i was using clears and those hyper white bulbs with higher watts. But since then i went back to stock bottom ambers with oem bulbs it hasn't melted. *knocks on wood* I think it depends just on the wattage of the bulb.
Old Jan 23, 2004 | 03:25 PM
The_Todd's Avatar
Farts in the shower
Default Re: 5th gen DIY fogs??? (spankey167)
Generally those aftermarket bulbs use higher wattages thus increase operating tempurature.....anyone do the 92-95 civic conversion and will this work for 4th and 5th gens?
Old Jan 23, 2004 | 04:38 PM
DrunkNRacer's Avatar
your corner lights allready act as a blinker.. they blink. Dont worry about that. Your gonna have to use clears on the bottom if you want to make them fog lights.. But I hear they melt.. So what I would suggest is actually buying some aftermarket foglights.
Old Jan 23, 2004 | 05:19 PM
aux's Avatar
aux
im running 194s in my bumper lights. no melting and they light up fine.
Old Jan 23, 2004 | 06:37 PM
fw190bvi's Avatar
Default Re: 5th gen DIY fogs??? (DrunkNRacer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrunkNRacer &raquo;</TD></TR><TR><TD CLASS="quote">your corner lights allready act as a blinker.. they blink. Dont worry about that. Your gonna have to use clears on the bottom if you want to make them fog lights.. But I hear they melt.. So what I would suggest is actually buying some aftermarket foglights. </TD></TR></TABLE> .....the corners blink????....i dont think so....of cousr my corners have been burnt out since i got the car, so i wouldnt really know....but i dont think ive ever seen a 5th gen w/ blinking corners, w/o doing the mod of course....
Old Jan 23, 2004 | 06:38 PM
pyrojeff's Avatar
The corner lights do not blink on the 5th gens.
Old Jan 23, 2004 | 06:42 PM
Default Re: 5th gen DIY fogs??? (pyrojeff)
I guaran-*******-tee you they do.. at least mine do.. 5th Gen cd5.. I just checked in the parking lot.. they sure do. .. They have 2 bulbs on each corner.. why do you think they have two.. and also.. the oem corners have orange on them.. which means they are used as a blinker.
Old Jan 23, 2004 | 06:46 PM
The_Todd's Avatar
Farts in the shower
And also NTM that if you view your car from the side the bumper light if flashing you won't be able to see due to its flat not rounded, hence the OUTSIDE corner bulbs necessity. So I have a question *raises hand* how did you get a 194 bulb into your bumper housing?? Please list mods.
Old Jan 23, 2004 | 09:00 PM
brads94accord's Avatar
the corners on my 94 lx i had blinked, but the corners on the 97lx i have now do not blink.
Old Jan 23, 2004 | 11:25 PM
Starrman85's Avatar
Default Re: (brads94accord)
i think the 94/95 corners blink, and the 96/97 do not blink.
Old Jan 24, 2004 | 07:18 AM
paul9luap's Avatar
Default Re: (STARRMAN85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STARRMAN85 &raquo;</TD></TR><TR><TD CLASS="quote">i think the 94/95 corners blink, and the 96/97 do not blink.</TD></TR></TABLE>
exactly.
Old Jan 24, 2004 | 08:45 AM
fw190bvi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrunkNRacer &raquo;</TD></TR><TR><TD CLASS="quote">I guaran-*******-tee you they do.. at least mine do.. 5th Gen cd5.. I just checked in the parking lot.. they sure do. .. They have 2 bulbs on each corner.. why do you think they have two.. and also.. the oem corners have orange on them.. which means they are used as a blinker. </TD></TR></TABLE>
no, theyre orange because in the US, all cars must have an orange colored side marker in teh front, and a red in the rear.....once again, if anyone has done this to a 5th gen, specially a 94-95, is it worth it....cause real fogs can cost a pretty penny
Old Jan 24, 2004 | 05:05 PM
ramoneguru's Avatar
Just tried it now....the 97 corners don't blink only the side markers blink (ones inside the bumper)....these side markers are orange which is why they are used as the turn signal and not the corner ones of the headlight
oem_certified_accord
Jul 6, 2007 12:23 PM
porter
Feb 18, 2007 03:40 PM
99silprelude
Oct 17, 2004 01:39 PM
93LUDE
Aug 31, 2001 02:21 AM
